Bought another bike.
Just brought home a craigslist mut. Old gal selling off her recently passed husbands collection. It’s a 1980 Xs650 special 2. 8700 miles, not licensed since 2011. Tank spotless inside. Engine free. Has title. I bought a 76 Xs650 new in 1976. Rode for 5 years. Loved that bike. Hoping to re-create my youth. She was asking $1200. Offered 800. Nope. Then 1000 nope. Then 1050 nope, she said she needed another 50 for the new now 20 year old rear tire her husband put on it. She has 5 more bikes to sell. A couple of hodakas, a ninja of some sort, an a couple trail bikes. I didnt look at any others cause my wife is gonna kill me if she ever finds out about this one.
- 511F0850-F855-4790-B2FB-DDFF6B201F6E.jpeg (260.27 KiB) Viewed 345 times
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
Re: Bought another bike.
You got an underground bunker to hide that one in? If so, I might need to borrow it. My wife gave me the ultimatum of having to sell one before I could buy another, and I have my sights on a pair of '94 Honda CB750 Nighthawks for $500 - neither is put fully assembled, and one doesn't have a title, but the pair would make for the newest bikes I've ever owned!
Best of luck on recapturing the memories. Looks like a fairly solid machine, including the "new" 20 year old tire that cost an extra $50. Gotta give her credit though, she stuck to her guns on it.
- Bugdaddy66
Good on you, my 81' is still my favorite for just blasting around town or running a fire road. Hard to beat for modifying too!
(A shameless pic of my XS650's to share)
- 2434.jpeg (146.36 KiB) Viewed 295 times
Todd Logan (Bugdaddy66)
2003 BMW F650CS (Wife Bike)
2009 BMW R1200RT
2009 BMW R1200RT
Soft spot for Hodaka's, about all I could afford as a kid. Had several.Gowing wrote:SNIP. A couple of hodakas,SNIP.
Ha! Me too! Had a B+. Was my first true love.Whiskerfish wrote:Soft spot for Hodaka's, about all I could afford as a kid. Had several.Gowing wrote:SNIP. A couple of hodakas,SNIP.
- Tin Member
I had a very finnicky 650 special. I suggest dumping the stock CV carbs and running Mikunis from MikesXS. You can also potentially run older XS650 direct slide carbs... but just buying new carbs and bolting them on and not worrying about it is a huge, huge plus IMO.
The original bakelite swingarm bushings are junk, and barely last 10k miles. Bronze bushings are available now.
The negative battery cable is attahched to a thin piece of sheet metal that tends to rust out. This causes hard starting. Mine would never start on the electric starter. It'd spin, but never have the power to fire and run the starter motor. It would only start reliably on the kickstarter. XS forum inidicated this was likely the negative battery cable, as I also had other problems (abysmally dim headlight, sometimes flaky signals, intermittent weak spark, etc). So, get a longer battery cable, attach it to a solid ground (motor mount bolt is a good place), and check that your starter motor cable isn't also corrosion city.
The bike benefits GREATLY from an aftermarket fork brace. The fork brace and bronze bushings really do tame the tendency to go into a tank-slapper above 80mph. Aftermarket shocks and tapered roller bearings in the triple tree together with the fork brace and bronze swingarm bushings will completely eliminate that tendency. The bike handles much, much better afterwards. Top it off with Progressive springs too, for a really solid ride. But, they're not as important as the rest. If you've got a high speed wobble, this will fix it. If you don't have one yet... well, you will eventually.
The 79 I had ran points and a mechanical advance. Later models went to electronic ignition, but I'm not sure if they retained the mechanical advance unit under the right chrome cover on the head. If you have one... open that cover and see if the springs pull the advance closed. Run the bike with the cover off and see if it appears to be operating properly - advancing as RPM increases, and the springs pulling the arms back in when at idle. If it's not working properly, the bike will be hard to start and sluggish to accelerate. Replacing the advance mechanism may or may not fix it! On my bike the shaft itself was slightly out of round, and produced just enough friction such that the advance mechanism wouldn't fully retract when the bike was running at idle.
Anyhow, enjoy your new bike!
Charles.
Charles.
