GL1100 engine siezure
- JohnBaxter
I recently bought a 1980 GL1100.
The guy I bought it from said the electrical system wasn't working right.
I bought a new AGM battery, a new voltage regulator, and a start relay.
Insert key, energize electrics, push start button... (click)
It seems the engine is siezed, is this common with 1100's?
When the Power of Love
Overcomes the Love of Power,
Then and ONLY then
Will we find peace.
Then and ONLY then
Will we find peace.
Re: GL1100 engine siezure
have you tried turning it over by hand?
- LuckyEddie
Remove the spark plugs, probably hydro locked.
LuckyEddie
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
- JohnBaxter
I have tried turning it over with the spark plugs removed.
I removed the timing cover and tried turning it over with a wrench in the crank.
Then and ONLY then
Will we find peace.
Then and ONLY then
Will we find peace.
Both belts are still intact? I would pull the valve covers (four bolts each side) and at least look for evidence of damage there; broken cam, rockers, bent valves. If it’s not moving either direction, this is less likely.
Lots of guys have luck spraying some penetrant in the plug holes and rocking the back wheel with it in gear. Heat can help too. (Acetone/ATF is a common suggestion/ keep it off paint) Leave it a day, rock it, repeat. If it’s just a little corrosion you probably get away with it. If it’s a lot, you might make it worse.
Safest way, but expensive is pull the head(s). If it’s been sitting a while, the original head gaskets are apt to have a short lifespan anyways.
- JohnBaxter
I have already bought a new top end kit. Both belts are in tactbut one looks newer. I'm wondering if I've been banboozled.
I guess the next step is head removal.
Then and ONLY then
Will we find peace.
Then and ONLY then
Will we find peace.
Just to clarify, you put a 17 mm socket on the shaft under the generator bolt cover, which is behind the spin off cover on the rear left side of the engine, could you turn it clockwise at this point?
I had an 81 1100 in the shop that seemed to be locked up, but turned out starter was bad.
- JohnBaxter
I did not try to rotate the engine via the generator bolt, I put a wrench to the center pulley under the timing cover.
Does that make a difference?
Then and ONLY then
Will we find peace.
Then and ONLY then
Will we find peace.
Should work just as well. Hope it turns (No pun intended) out well for you.
Well the ultimate bamboozle here a few years ago was a guy who bought a running bike. It was running rough, checked compression and zero on a cylinder. Pulled the head and the motor had been disassembled, a piston removed, reassembled with no piston or rod, and sold as a runner.
You never no.
You never no.
if one belt looks newer, was it installed correctly? check the timing marks on the cam. Don't know why anyone would charge onlt one belt,......unless one broke. Which might cause other damage
- x_wing
I'm gonna follow this thread too just in case!
1980 GL1100 (X-Wing build)
1982 GL1100 (restoration project?)
"Never aim a law at anything you don't intend to harm."
- Aberdale
Following as well.
I'm currently in the same situation as the OP. 1976 Gl1000. Spark plugs are out. Each cylinder soaking with a combination of PB Blaster and ATF (except for the cylinder with the open exhaust valve). I'll give it a week or two . . . . unless I get impatient and just pull the heads.
'dale
'dale
I'd rather be lucky than good lookin'.
1970 Honda CB450
1976 Honda GL1000
1982 Honda CX500 Turbo
1981 Yamaha SR500
1972 BMW R75/5 Toaster
1978 BMW R100S
1982 BMW R100RS
1987 BMW R80RT
1989 BMW K100RS
1991 BMW K1
1987 Harley Davidson Tour Glide
1990 Harley Davidson Heritage Softtail
1970 Honda CB450
1976 Honda GL1000
1981 Yamaha SR500
1978 BMW R100S
1982 BMW R100RS
1987 BMW R80RT
1989 BMW K100RS
1991 BMW K1
- ancientdad
Wow - that took some serious cojones. My Dad told me of a car engine (straight 8) that he worked on back in the day that had been done like that, but a bike... man.ericheath wrote:Well the ultimate bamboozle here a few years ago was a guy who bought a running bike. It was running rough, checked compression and zero on a cylinder. Pulled the head and the motor had been disassembled, a piston removed, reassembled with no piston or rod, and sold as a runner.
You never no.
'73 CL450K5 brat
'84 VF1100S naked
among past rides
'79 and '80 CBXs
'75 and '76 GL1000s
(2) '73 CB750K3, '78 CB750K8/F2
'84 VF1100S naked
among past rides
'79 and '80 CBXs
'75 and '76 GL1000s
- JamesPal
Tom, good to see you. Back in the day my dad had to pull a piston out of his Model T. He said it ran a little rough but he drove it around for a few months. At 20 HP on a good day, I'm not sure how much was left on 3 cylinders.ancientdad wrote:Wow - that took some serious cojones. My Dad told me of a car engine (straight 8) that he worked on back in the day that had been done like that, but a bike... man.ericheath wrote:Well the ultimate bamboozle here a few years ago was a guy who bought a running bike. It was running rough, checked compression and zero on a cylinder. Pulled the head and the motor had been disassembled, a piston removed, reassembled with no piston or rod, and sold as a runner.
You never no.
I cannot imagine anyone going to the trouble of taking a piton and rod out of a Goldwing engine and putting it back together.
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
