Shortend the frame by 10 cm
removed the steering lock because of the new front fork
fixed up some holes of corrosion
welded a new crossmember in the frame instead of centre stand.. Tt was rotten anyway
welded the exhaust mounting point bushes is the back of the frame
Made the fame higher with a ridge in the lenght of the frame because the hight of the seat
Recent collection goldwings
GL1000 k2
Gl1000 k2 cafebike Desi...
Gl1200 aspencade '84 made naked
Gl1200 Interstate '86 ( for sale )
Gl1500 '89
Unfortunately your Goldwing cafe racer was not choosen up tiil now as BOTM to participate BOTY for this year.
I personally believe that you would have had a good chance to end up amongst the best 3 bikes.
Nevertheless, may be there are chances for you for the coming year.
BTW: very interesting posts how you modified your bike!
Best regards, Ruud
Proud winner of the NGWClub-USA contest Bike of the Year 2016------ GL1000 K1 1975
Hi.. I let the bars made by stunttoys.com comform own specs. I think they work out very well. The triple tree is the base from a kawasaki zx9r cut it of and welded in the original gl1000 steering stem. the steering plate is custom made. Also the seat is hand made by myself from a mould made of styro foam. Then made a contra mould at and made the seat as it is from polyester. Than i made the raster for the tail lights. made a print with red LED 's tail and brakelight and 2 orange blinker leds. Than filled it with a Ressin.
Hope you got the anwsers you askes for?
everything is hand made or customized . I think the only thing thats standard are the side covers and steps
kind regards Alexander
GL1000 k2
Gl1500 '89
"Can't see the paint when your looking thru the handlebars..........." -Oldewing "I'd rather Ride than Shine" -RAT Me Too!!
