12 Volt Air Compressor
- Solina Dave
The shed where I keep my bike has no electic power. I have a small air compressor with it's own tank, that when full, can be used to top up my tires. It works great. The storage shed guy lets me plug it in to his office receptacle to recharge the tank, but it's hit and miss as to whether he'll be there or not. If I don't ride for a period of time, the air in the tank leaks out, and I'm beat. Catch my drift? I have a small 90º fitting on the compressor hose to fit a hard-to-get-at valve stem on my '78s Comstar wheel. Service station air lines are out of the question.
What I need is a 12 volt compressor. I always have my car there when I pick up the bike, so that would be more than enough to power up a decent 12 volt air compressor.
Does anyone have a suggestion for a reasonably good unit, that's cheap.
Thanks........... Dave
"ASSUME NOTHING"
1st motorcycle-1977 Honda CB550F Super Sport
2nd motorcycle-1978 GL1000
"Not riding a motorcycle is wrong"
- chewy999
Re: 12 Volt Air Compressor
Dare I say you could get a foot pump!
Oh look, yes I do!
Oh look, yes I do!
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
I bought a little 'Slime' brand one that is small enough to pack on the bike. Not overly fast, but tops off the tires just fine. IIRC, was less than $30...
- ritalz
+1 on the small 12 volt unit. I also snip the ends and attach some clips to attach directly to the battery. That keeps from messing with any fused circuits because these things can draw lots of power.
I carry a small air compressor from a car we used to own. Found one silimar on line. I have used it a few times. Nice package and works well.
- F2DE0FAD-AFBE-4B1A-BC8A-FA68750E04A3.png (584.66 KiB) Viewed 346 times
- 62DEE2E9-75A3-4E0B-8C61-A656A2EDBFF9.png (270.39 KiB) Viewed 346 times
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
- salukispeed
+ one on the mini Slime compressor and alligator clips. I have there smallest one i could find in the saddle bag for the inevitable issue. Was useful on my sons bike last year
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
- Solina Dave
Thanks for your suggestions everybody. It's looking like the small Slime 40001 or the Slime 50001, are moving up the list fast. 4.3/5 reviews.
The 40001 has a 300 psi compressor. And the 50001 has a 100 psi compressor, but also comes with a can of sealant, and is slightly less money. I wouldn't need anywhere near 100 psi, let alone 300 psi. Up here in "The Great White North", they're available on Amazon.ca for $50.68 for the 40001, and $46.51 for the 50001, taxes in, and free delivery. They're both about the same size.
Do you think there's any significant advantage to a 300 psi unit over a 100 psi unit? Maybe a more robust build. I don't know. The can of sealant might get you home!
Thanks again................ Dave
https://www.amazon.ca/Slime-40001-Motor ... e+inflator
https://www.amazon.ca/Slime-50001-Power ... Repair+Kit
"ASSUME NOTHING"
- salukispeed
Did not look at the specs but lower pressure at higher volumes can often be the better trade off and is better in the 40 psi region we work. Most are shore duty cycle and good for 15 minutes. The two I see links to look the same except for the slime and added connectors
Honda 72 CL100 sold
1970 CT 70
1970 CT 70
- todd54219
From personal experience, be aware that cans of sealant may not work on motorcycle tires. Most of the cans of sealant have a fixed, straight nozzle. You cannot screw those cans on a motorcycle tire, the spokes or wheel will not let you. You need something that has a right angle to get it on the tire valve.
Todd
Todd
1976 Yellow GL1000
1976 Yellow GL1000
- Solina Dave
Thanks for that Todd. Actually I do keep a 90º fitting on the bike for somewhat that very reason. Most of the time, I find it impossible to use the service station air nozzles, in the tight quarters presented by my Comstar wheels. But I do keep a 90º fitting onboard, for an emergency, just in case I ever need it.todd54219 wrote:From personal experience, be aware that cans of sealant may not work on motorcycle tires. Most of the cans of sealant have a fixed, straight nozzle. You cannot screw those cans on a motorcycle tire, the spokes or wheel will not let you. You need something that has a right angle to get it on the tire valve.
Todd
Regarding my potential purchase of a 12 volt compressor, I am at times finding it difficult to pinpoint one with a 90º fitting. A lot of times the descriptions presented, don't specify that option in their write-ups, or their write-up photos. The fittings for the Slime units look like they include the 90º fitting, that locks on to the valve stem. So that looks good.
Thanks again.............. Dave
"ASSUME NOTHING"
- chewy999
I've got one of those, one of the best 'tools' I ever bought!Solina Dave wrote: Actually I do keep a 90º fitting on the bike for somewhat that very reason. Most of the time, I find it impossible to use the service station air nozzles, in the tight quarters presented by my Comstar wheels. But I do keep a 90º fitting onboard, for an emergency, just in case I ever need it.
Previous Rides,
Current bikes
Current bikes
Mine is the 40001 series, and it has the 90 degree fitting on the hose...
- Solina Dave
Has anyone ever had occasion to use the Slime sealant? And how did it work? Did it get you home?
..........Dave
..........Dave
"ASSUME NOTHING"
Should get you home. But if you take your tires to someone else to have them changed don't expect a happy tech. Especially if you don't warn them that the stuff is in there.Solina Dave wrote:Has anyone ever had occasion to use the Slime sealant? And how did it work? Did it get you home?
..........Dave
- Solina Dave
Just for a bit of added information regarding the Slime tire inflators. The small, and seemingly very usable model 40001, and the model 50001 package (same compressor but also including a can of Slime sealant), are being discontinued. I'm still seeing these products for sale on Amazon, but probably not for long.
I contacted Slime customer service with a product performance clarification question, and was told, at that time, about the discontinuation due to low product sales. They don't seem to be selling enough of these units, to motorcyclists, to warrant keeping them in their catalogue.
...................Dave
"ASSUME NOTHING"
