Suspensions and stuff
I consider myself a pretty fair 'wrench' as far as DIY stuff goes; if nothing else, I at least have enough sense to know when I'm in over my head. Such is the case when it comes to suspensions, geometry, track, trail, and all that good stuff. Does anyone have any suggestions/links for good reliable in-depth info regarding everything 'springy?'
Re: Suspensions and stuff
If you have some time you can search "Suspension for Mortals" on Youtube. It is a couple of hours of suspension setup, geometry, and other information that can help you wrap your head around it. It is presented by Max MacCallister, who is the President of Traxxion Dynamics. Most of it is broken up into individual chapters, so you can work your way through them.
I am sure there are lots of other resources out there, but it would be a decent start.
Thanks! I have all winter, lol!
Just don't feel bad if you still don't fully grasp it all at first.
- 3 Replies
- 157 Views
Last post by Whiskerfish
