Cool weather tire maintenance
salukispeed
Post by salukispeed »
I was nearly bit by my lazy attitude. The weather has dropped to low 30's this week and I continued to just hop on my 84 interstate as usual. A normal expressway ramp nearly got me when the tire grip suddenly seemed to go away. I got lucky and did not fall. When I got home I found the the tire pressure was 24 in the front and 25 in the rear. I know better and was just lazy. So check your tires and again watch for wet leaves. as both will get you hurt!!!!
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
Re: Cool weather tire maintenance
That goes for vehicles with 4 wheels too. ;)
duke182
Post by duke182 »
Several years ago 19 degrees and that same lazy streak put me on my face.
I kept the chewed up visor for the wall of shame.
1984 1200 standard
click pic to see my gallery
vote in my poll
dontwantapickle
Post by dontwantapickle »
:-D
Last edited by dontwantapickle on Sun Jan 14, 2018 2:09 am, edited 1 time in total.
desertrefugee
Post by desertrefugee »
78F at 7:30PM. I will keep the excellent warning in mind, but may not see the pressure drop for a while...
Many Helicopter rotor blades are pressurized to about 8-10 psi of nitrogen as part of the crack detection system. People used to get pissed off when I would write up a work order every fall to top them all off. A fair amount of work but would save us from having busted launches in the long run. A sudden drop in outside air temp makes a big difference in pressures and sometimes it was enough to provide a false warning.
The same thing happens with tires when the temps drop. 41 degrees F here yesterday morning from an overnight low of 70 just a couple weeks ago. Bet my tires are down a good 6 or 8 psi right now.
Steve81GL1100
Post by Steve81GL1100 »
In this cool fall weather, I check pressures daily. Before I had the GL, I could detect a noticeable difference in handling with as little as 1 psi drop in pressure in the tires on my Aprilia. On the GL 1 psi is not so noticeable, but then it's twice the weight. I can definitely tell when it gets to the 2-3 psi area though -- feels like mush. Rather take a couple minutes to check and top off than contemplate some severe consequence.....
Steve
Steve
1981 GL 1100 Standard, 81 Interstate bags, 84 GL1200 pegs, sometime National Cycle PlexiStar windshield
1996 BMW R1100R
2007 Piaggio X9 Evo500, wife's ride so she can keep up with the GL
1980 Vespa P200 (also wife's), restored, with custom paint, custom trim
