Lots of good ideas.
Dont forget that just like cell phones, credit cards sometimes fail to work also.
Carry a reasonable amount of cash. Well hidden. And dont use it unless its your only option.
Tool Kit/Roadside kit - suggestions welcome
- duke182
Re: Tool Kit/Roadside kit - suggestions welcome
1984 1200 standard
click pic to see my gallery
vote in my poll
1984 1200 standard
vote in my poll
When I first got my 75 wing the first breakdown was a broken clutch cable. I bought a selection of cable stops from oreillys. Got me by till my cable got here. I ride with one always now.
- image.jpeg (15.66 KiB) Viewed 186 times
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
Some good suggestions, thank you. Adding to the list. Those cable stops are a good idea, might buy a few and toss them in a small baggie. I just replaced my clutch cable and lubed it, but you never know.
1975 GL1000 - Delkevic exhaust with stainless studs, Corbin Touring seat, Race Tech Gold Valve cartridge emulators, Progressive 11-1100 springs, Progressive 412HD rear shocks, Shinko 230 tires, Fork Brace, Trucklite 27270c headlight, X-Arc Signals (run, brake, turn), Hydraulic Clutch conversion, EBC Clutch discs, HD springs, and Barnett Steels + Plate B eliminated. BikeMaster DLFP-50N18L Lithium battery, Rick's Motorsports CBR600F4 Mosfet Regulator/Rectifier upgrade.
- warhead_71
Ahhh!! I didn't realize you were running tubes. I'm pretty sure my 78 is tubeless since it doesn't have spokes. Brain fart.MegaDan wrote:plugs don't tend to work with inner tubes well. Hence the spare tubes and tire irons
- hoganJr
I always kept a set of tools dedicated to my '77. Anything I used regularly on the bike went with me on the road. Plus most of the stuff in the "Whiskerfish" kit. As for tire irons...you gotta be a special kinda man if you can get break down a wheel on a GL1000 to the point of patching a tube on the side of the road.
HoganJr
HoganJr
1991 GL1500
Depending on who you ask, I am special. To my girl, the good kind. To my friends, the "ed" kind.
I've done tubes before on bikes. I'm not the fastest, but swapping a tube out isn't terribly difficult either.
Forget that torx tool. Multi tool as well. Best advice was given above. About the only other thing that I would suggest: replace those old valve stems. I put metal ones on my bike and also new metal valve caps. You have recently replaced your timing belts?
Have yourself a safe trip! Or two, or more!
Experience is what you get when you didn't get what you wanted.
Do your work with your whole heart and you will succeed! There is so little competition.
Come to kindly terms with your ass, for IT bears YOU!
1999 Valkyrie built from parts. One owner.
1981 gl1100 naked, Cosicud. Sold!
1981 gl1100 naked. New project.
- x01660
So one of my saddlebags has my toolkit:
Spare pull and push throttle cables
Spare clutch cable
2mm-19mm socket set
8mm-17mm box wrench set
Vice grips
Pliers
Wire cutters
Wire
monkey wrench
allen wrench set
various phillips, standard and JIS screwdrivers
600 mph tape
Gorilla tape
Zipties of various sizes
Spare headlight and taillight bulbs
LOTS of spare fuses
Spare innertube
Latex gloves
Battery powered tire inflator
That's what I carry around all the time. Other stuff gets added when I'm going long distance (over 200 miles)
I like to think that its adequate....
Spare clutch cable
2mm-19mm socket set
Vice grips
Pliers
Wire cutters
Wire
monkey wrench
allen wrench set
600 mph tape
Gorilla tape
LOTS of spare fuses
Spare innertube
Latex gloves
-x01660
"The best motorcycle is the one well ridden"
"The individual has always had to struggle to keep from being overwhelmed by the tribe. If you try it, you will be lonely often, and sometimes frightened. But no price is too high to pay for the privilege of owning yourself." ~Friedrich Nietzsche
- 19 Replies
- 922 Views
Last post by Gashog
- 4 Replies
- 455 Views
Last post by 5speed
- 28 Replies
- 1502 Views
Last post by Sidecar Bob
- 13 Replies
- 574 Views
Last post by Rat
