Rear drive oil.
Rear drive oil.
I saw where Randakk's recommended a oil that would help seal the rear drive. I have looked on his site but can not find it. Can anyone tell me what kind it was?
79 GL1000,75 GL1000,76 GL1000 LTD,70 CB750k JDM, 79 CBX, 2000 Valkyrie CT 2008 Goldwing Roadsmith
Trike and another 76 LTD bad shape, and several more for parts.
Re: Rear drive oil.
I do not recall seeing that. I know it needs to be hypoid oil due to the gear design or it can build excessive heat and promote wear. Make sure you are leaking oil and not just slinging grease residue from the hub interface.
- gregforesi
Re: Rear drive oil.
I saw that here recently but I can't remember what brand it was. You could try sending Randakk an email.
My own opinion is that even in cases where those types of fixes actually work - they're a stopgap at best and don't address the problem directly. A worn seal needs to be replaced. The big seal and o-ring on the output of the 1000 final drive were still available last time I looked. Re-torquing the big retaining ring to set the gear preload is the tough part.
2006 GL1800 (Brutus Maximus)
- gadelsperger
Re: Rear drive oil.
George in Rancho Cordova (Sacramento is a suburb) CA
- gadelsperger
Re: Rear drive oil.
- brokentoe
Re: Rear drive oil.
I had a tiny leak so I tried the Lucas Hub oil. The leak is now gone and that's been since maybe January of 2013. Anyway it's been quite a while. The Lucas product also smells better than the Kawasaki product I was using.
Faith, Family and Friends
'75 GL1000 (Feb 2012 BOTM)
2014 Softail Deluxe
1966 Suzuki S 32-2 Olympian
First Fire on Youtube!
2014 Softail Deluxe
Re: Rear drive oil.
Thanks, that is what I needed to know. I have a couple of GLs with just enough leek to get it dirty but not even close to a drip.
Dannie
Dannie
- 6 Replies
- 519 Views
Last post by CYBORG
- 8 Replies
- 670 Views
Last post by rcmatt007
- 3 Replies
- 233 Views
Last post by Whiskerfish
