Bolt hole size for front blinkers 1978 GoldWing
- tonyjohnston1970
Does anyone know the size of the bolt holes for the front blinker stems to screw into on a 1978 GoldWing?
Tony
Oklahoma
1978 GL1000
____________________________________________
"The odds may change, battles may be lost but those who persevere, rarely lose the war."
Sir Winston Churchill
Oklahoma
1978 GL1000
- n5zhu
Re: Bolt hole size for front blinkers 1978 GoldWing
14X1.25 mm Where in OK are you?
In the sticks So. of Heneryetta OK
1992 Suzuti VX800 Gone Traded for 2nd 78 GL1000
1978 GL1000 X2 1 Up and Runing 1 to go in the shop for work
- cmyoch
I assume the bolt hole size is the same for a '76 as well? I had a thought of tapping a hole to mount a mirror to.
1976 GL1000
1978 Yamaha XS650
1984 Harley Davidson XLH1000
1969 Camaro Z28
1977 Redheaded Wife (Better move her to the top of this list)
1978 Yamaha XS650
1969 Camaro Z28
- n5zhu
Most mirrors are 10X1.25 The 14X1.25 is in the stock headlight mount ears. 73 Patrick
- gregforesi
I recall the blinker holes are M12-1.5 (fine thread). The mirror holes are M10 fine thread.
2006 GL1800 (Brutus Maximus)
- n5zhu
Greg I used a 14X1.25 tap to clean up the thead in my fork ears with very little force to run the tap thu so can someone with the oem mounts check this out?
I found a 12 bolt to be way louse and a 14 to fit snug73 Patrick
- tonyjohnston1970
South Central Oklahoma. Thanks for the info.
Tony
Oklahoma
1978 GL1000
Oklahoma
1978 GL1000
- n5zhu
bump
- Scottinaz
They are indeed a M14 fine thread. If they were M12, I would have had the tap on hand to make my own signal mounts. Instead, I was beholden to factory parts (cant find fine thread metric bolts that large at the hardware store...)
'76 GL1000
- n5zhu
Wholesale Tool has tap,die and die handel for $28 worhs well on alum.
- 8 Replies
- 542 Views
Last post by Sidecar Bob
- 1 Replies
- 440 Views
Last post by 914Driver
- 4 Replies
- 543 Views
- 6 Replies
- 658 Views
Last post by luigipasto
- 11 Replies
- 327 Views
Last post by Track T 2411
