neutral switch
FLASH2002
neutral switch
Post by FLASH2002 »
Today I was trying to reconnect the wire for the neutral switch, is that a good place to screw a wire ? :x I thought Satan devil1 was going to appear, at one point. I played with that thing till I was blue in the face, then I said to my self, there must be a better way. So I took that stupid screw out and got a longer screw the same size, cut the screw about 1/2'', screwed it at the end of a small hose and was able to screw it at that angle, screwed it part way and then pulled the hose off. Now I was able to connect the wire and install a nut to hold it in place and tighten with a wrench , a lot easier than playing with a stupid philips. I hope this might help a few people who might have the same problem.
_________________________________
'79 GL1000
'82 GL1100
'82 GL500
'84 GL1200
'03 GL1800
Re: neutral switch
you are right.... what nasty engineer was having visions of the poor sot who would have to get to it.... or the sump screen cover
