What coils & wires do you recommend
I have a 78 GL1000, and been having some issues rebuilding this bike. I had no clue about its history, everything I've learned I've found on my own. Yesterday I discovered it has the Dyna s ignition set up, I discovered this while trying to set the timing. Today I got the timing spot on and when I was trying to start it she was backfiring, popping & and just ran terrible. A little further into it I discovered the plug wires weren't making contact in the plug cap. After retighten the wire into the plug cap it ran a lot better. Now this bike still has the original coils & wires, I'd like to improve this to something better, as the stock plug wires and hard and brittle. If cost isnt a factor what would you purchase for your bike and why?
Thank you
Donnie
Thank you
Donnie
Re: What coils & wires do you recommend
Dyna 3ohm coils and solid core wires, run resistor plugs.
Have you gone through the carbs yet ?
Hello Donnie
Many of our members have utilized Dyna 3 ohm ignition coils.
The original Dynatek ignition system components- Dyna S and Dyna ignition coils-have become outrageously expensive though. .
Cedric, aka cfairweather, brought the much less expensive generic equivalent of the Dyna 3 ohm ignition coils ( DC1-1) to our collective attention with this document.
These instructions are specific to the primary wiring details of the 1975-1977 production GL1000 units.
1978-1979 production units primary wiring details are not as straight forward with ease of eliminating the stock ballast resistor.
The details for the 1978-1979 DC1-1 coils' installation are located close-by in the same document. We can assist as needed.
FIRST Thing, search for the best deal amongst the many listings for a pair of (or 2 single unit s) DC1-1 ignition coils on eBay.
This Topic will get you started with a well reviewed equivalent ignition coil installation procedure
viewtopic.php?t=77232
Cliff (74yrs )
I bought the dyna 3 ohm green coils that come with plug wires, what spark okug number do you suggest? Is is a resistor plug or not what's the difference as I'm trying to learn all I can.
Are you replacing the original NGK spark plug caps, too? XD05F (NGK #8072)
If yes, the caps have an internal 5000 ohm resistor .
NGK D8EA (their #2120) is the original non-resistor sparkplug installed on the Factory production line. <GL1000 Shop Manual, Tuneup chapter
There are several ways to go with selections of spark plug wire ends And spark plugs. too.
Regarding my '75 gl1000 ignition details, I use NAPA copper core spark plug wires with straight rubber boots and NGK Iridium DR8EIX (#6681) resistor spark plugs.
Its ignition system was upgraded to a Dyna S kit and Dynatek 3 ohm coils 10 years ago as well
Cliff (74yrs )
I've also used 5 ohm coils. They work well with the Dyna S and will work better with points if you ever want or need to revert to stock.
What is the reason to run either a resistor spark plug or the ngk resistor style caps? Every thing I've read says to run a resistor plug or cap's if you have electronics like a ecu or other, I've also read that you get a better spark without the resistor, I don't have a clue is why I'm asking, please advise.gltriker wrote: ↑Thu Dec 22, 2022 8:53 am Are you replacing the original NGK spark plug caps, too? XD05F (NGK #8072)
I was hoping you wouldn't ask me to answer that question, Donniedonniebnd wrote: ↑Thu Dec 22, 2022 6:57 pmWhat is the reason to run either a resistor spark plug or the ngk resistor style caps? Every thing I've read says to run a resistor plug or cap's if you have electronics like a ecu or other, I've also read that you get a better spark without the resistor, I don't have a clue is why I'm asking, please advise.gltriker wrote: ↑Thu Dec 22, 2022 8:53 am Are you replacing the original NGK spark plug caps, too? XD05F (NGK #8072)
A Dyna S, and Dyna ignition coils, and copper filament spark plug wires, in combination, just sneeze at NGK resistor spark plug caps and resistor spark plugs. hot hot hot
I read somewhere in NGK publications they state their resistor spark plug caps and resistor spark plugs can be used in combination together. Why would that even be considered?
FOUND IT!
https://www.ngksparkplugs.ca/resistor-covers-and-caps
Swapping the OEM non-resistor D8EA spark plug with their NGK GL1000 application chart approved DR8EIX spark plug is a reason why! Its an expensive spark plug, but works great in trike's engine.
Consulting the NGK website for their spark plug features is very informative. https://www.ngksparkplugs.ca/products
but Wait... There's More! An additional NGK resistor sparkplug number AND an XD05FP sparkplug cap, too NGK-8641
https://partfinder.ngksparkplugs.ca/res ... Motorcycle
Last thought, Donnie-
A very common, and easily accomplished strategy to eliminate the resistive component in the NGK XDO5F spark plug cap is to completely remove the 5000 ohm ceramic resistor and replace it with a similar dimensions piece of brass round stock.
( 4mm x 25mm? )
Done
Cliff (74yrs )
gltriker wrote: ↑Thu Dec 22, 2022 9:12 pmI was hoping you wouldn't ask me to answer that question, Donniedonniebnd wrote: ↑Thu Dec 22, 2022 6:57 pmWhat is the reason to run either a resistor spark plug or the ngk resistor style caps? Every thing I've read says to run a resistor plug or cap's if you have electronics like a ecu or other, I've also read that you get a better spark without the resistor, I don't have a clue is why I'm asking, please advise.gltriker wrote: ↑Thu Dec 22, 2022 8:53 am Are you replacing the original NGK spark plug caps, too? XD05F (NGK #8072)
FOUND IT!
( 5mm x 25mm? )
I believe I'm going to try your route, Dyna s ignition with the dyna green coils, copper core wires using the caps that came with the coil pack kit, firing the NGK 6681 resistor plugs. You stated 10 plus years and still going is hard to beat. With that being said to which I wont do but need to know, what would happen if I ran this same setup but used the non resistor factory plug's? I have read a lot of info that you sent and what all I've found but nothing on what would happen if I didn't run any type of resistor
snip-what would happen if I didn't run any type of resistor.
As far as I know, nothing that would adversely affect any part of an otherwise stock ignition system configuration GL1000, itself.
Might RFI "noise" adversely affect (possibly injure?) the safe operation of a Dyna S ignition assembly?
Contact Dynatek Technical Support Staff at 800-928-3962 EXT 1 or e-mail to info@dynaonline.com.
completely Done now
completely Done now
Cliff (74yrs )
I always need to know the why's and what if's and just an answer, this way I can understand.gltriker wrote: ↑Fri Dec 23, 2022 3:33 am snip-what would happen if I didn't run any type of resistor.
completely Done now
Thank you for all this info, you have been most helpful
Donnie
As I understand it the resistor also affects the duration of the spark event.
FWIW, mine has a Dyna S ignition with GL1500 coils, 7mm solid copper wires (I bought a length at a small engine parts store) and XD05F-R caps (the same as stock except red). Details at link below
viewtopic.php?f=1&t=60509&p=667932
I’ve called NGK tech a couple of times and years ago talked to their “techs” at a show and have gotten several different answers. The plug cap 5kohm resistance is meant to act as a pseudo choke to properly fill the coils, over the years we’ve preached to replace any plug cap that is over the 5k ohm resistance as they tend to cause all kinds of little “run” problems (to much resistance?) the caps are supposed to be less than 5k , so common sense would dictate that adding resistor plugs which properly spec’d for your wing will provide another 5k for a total of around 10k resistance, should cause intermittent run issues.
So I’ve recently taken to removing the resister from the caps and using a piece of brass/copper to replace it and then just using resistor plugs which get replaced/refreshed periodically. Just keep in mind that the resistor caps were used w/o resistor plugs and used solid core plug wires. It’s not really about EMI but more about fully charging the coils. Anyway that’s my take.
On the generic green China 3ohm eBay coils, I have used them and they do seem function fine, and at $50 a pair it’s hard to argue with that.
The resistor can be in either the cap or the plug but NOT in the wires. So called resistor spark plug "wires" are basically carbon impregnate4d string and they don't last on motorcycles.
- 191 Views
Last post by egelasi
