1978 Battery harness
Previous owner added this inline fuse to the positive battery harness on my 1978 GL1000.
Can anyone tell me why, and should I leave it, or what is the best way to correct it?
- 20221203_144058.jpg (184.16 KiB) Viewed 438 times
- 20221203_144111.jpg (158.93 KiB) Viewed 438 times
1978 GL1000
1986 GL1200 Aspencade
With California Sidecar
1965 CA95 Benly
1965 CA95 Benly
- Lucien Harpress
Re: 1978 Battery harness
Normally that runs to the stock main fuse, which is the flat metal strip kind that gets held in with a couple of screws. People like to change it to a bladed fuse because the latter is easier to find.
If you're not concerned with the bike being 100% stock, and the guy who installed it did a good job, there's nothing wrong with it.
Great, thanks.
1978 GL1000
1965 CA95 Benly
1965 CA95 Benly
That is a better setup than the “flat” horseshoe oe fuse as the oe fuse tends to get cracks in them with age that causes all kinds of weird no power issues, I replace all of mine with the modern blade fuses, much easier to find if you need one and more reliable.
That is a low current fuse holder (you can tell by the skinny wires). I think if it was mine I'd replace it with a blade fuse holder that is intended for higher current and do something about the live conductor hanging out of the ring lug's insulation before I used the bike much.
I agree with Bob. I like the upgrade to an inline blade type fuse, but that setup has a number of issues. I would remake it using heavier components and no quick connects.
Bob,,,
No matter if you leave it or replace it with a higher rated holder make sure to put it on your annual maintenance cycle. I have seen too many of these melt down and leave you stranded or worse start a fire. Just pull the fuse and clean the holder and the fuse with some contact cleaner and a acid brush. Just takes a couple minutes each year.
I have fuse holders with waterproof covers like the pic below on my bikes and I've never had a problem with the contacts. IIRC, the one on the winter machine has been in use since 2006, mostly on salted roads and I've never felt the need to clean the contacts in it.
Thanks. It does look like it might have gotten a little toasty at one point. I will replace it with a lower gage as suggested.
1978 GL1000
1965 CA95 Benly
1965 CA95 Benly
A lower gauge wire does help keep the smoke inside the wire, but does not guarantee it, good upgrade for sure.
