'76 idle bogs when blipping throttle
Feels like I'm getting closer. When warm, the engine idles fairly well at around 1100 rpm. Takes a while to warm up admittedly, and I need a lot of choke and gentle throttle encouragement to get it to idle all on its lonesome. It's getting a bit cold in my garage however these days (not much above freezing the last few days and only getting colder from here on in) so maybe that has something to do with that.
My question for today is, why does the idle bog when I blip the throttle but rpms go up smoothly when I roll on the throttle? I've checked the plugs (somewhat sooty) and my mixture screws are at the three turns out recommended setting. No huge amount of smoke belching out of the exhaust when I blip the throttle (or roll on it), stock carb set-up (rebuilt with Randakks kit), new air filter. My guess the bogging is caused by a rich mixture, but it's a guess at best. Here's a vid -
https://www.youtube.com/watch?v=HBEg1pmc9u0
I tried turning the mixture screws a half turn in each, to no discernible effect.
Thanks for the help with my previous question regarding the valve check procedure. Getting the valve clearances in spec definitely helped the flaring idle (rpms were going up all by themselves), now the idle is much better.
Re: '76 idle bogs when blipping throttle
Cold weather cold engine.
Betcha if you remove the air filter cover and look into the " plenum" when you blip the throttle, you might hear(pop), and less likely, see (flame), an off-idle backfire into the plenum from at least one carburetor. A *lean* fuel mixture ratio, intake backfire.
Remember, the carburetors are correctly, engine idle speed synchronized when the entire engine (including carburetors) is at completely full operating temperature. Mike Nixon gave the recommendation to set each carburetor's air/fuel pilot mixture screw at 3 turns out from seated.
In a strictly layman's interpretation I would presume to 'explain' it; one incidental benefit of that richer air/fuel pilot idle mixture is to crudely - especially when *blipping* an unloaded GL1000 engine - simulate the contribution an integral accelerator pump provides to address engine hesitation which usually accompanies rapid throttle opening;
In gear, pulling away from curb, a dynamically loaded engine is another 'story.' To the point... blipping of throttle is not useful then.
If your synchronizing gauges were all hooked up, a *lean* fuel-to-air ratio backfire occurring in an individual carburetor throat will be displayed as an abrupt air pressure spike from that one's intake manifold synchronizer adaptor.
Cliff (74yrs )
Long intake runners make for long warm-up times. It will improve as the carb tune gets better. Bogging on blipping is often an indication of lean. I can't remember if the '76 is one with carbs particularly prone to this. There is an easy fix for those that are (visit Randakks blog pages).
That article basically says to remove the size 115 pilot jets from the 4 brass elbows. Obtain smaller air jets, size 60, and drill them out with a #59 drill bit for a 76 model. This will make the idle richer and solve the off idle issue. It will also make the bike easier to start.
Here is a link to entire article:
https://www.randakksblog.com/how-to-cur ... flat-spot/
Well, there it is. Thanks for the insight and links - seems like the "off-idle" situation is a quirk these bikes are known for. Very interesting read on how to address it by soldering closed the idle air jets and then drilling them out with a #59 micro bit to enrichen the idle circuit. I'll give it a try and report back.
Also good to learn more about the longer-than-usual choking and slow warm-up times on this bike too. Will be interesting to see what effect drilling out those jets will have.
I’m not a fan of drilling jets, nearly impossible to make them all the same. I just buy new #110 jets from either Jets-R-Us or usually PJ’s Motorsports. You get much more consistent results. I also replace the fuel jets, the primary main which on your 76 is a #62 stock with a #65 and the stock #120 secondary mains with #115’s . These changes provide a much flatter fuel curve richening up the super lean low end and leaning out the pig rich top end. All bought through PJ’s.
The off idle (bog) leaness that you are seeing is the result of the #62 primary mains and the #115 air jets (in the brass elbows). I have found a lot of improvement with the jet changes I mentioned above BUT will add that these are vacuum slide carbs without an accelerator pump so a little bit of this is to be expected.
Also, as mentioned above a good, precise sync of your carbs will help as well. What are you using for ignition ? Stock points & coils ? Really lean jetting like the stock jetting is hard for a stock barely adequate ignition like the gl has.
I will add that once you go for a ride that your GL as is would run just fine under normal load !
I buy cheap third party kits just to get the size 60 air jets. It is easy to drill them because they already have a starter hole. Just hold the jet with two fingers and push it into the bit. They come out perfect every time for me and the jets work as well as any factory Kehin jet made. The pilot jet is the primary cause of the problem he is having and it needs to be smaller to richen up the low RPM mix. The mains do play a small part, but they come into play much more at higher RPMs.
If I had a wide open issue, I would be looking at the main jet circuit, not the pilot jet circuit even though it might play a minor role. I am not saying your primary and secondary jet suggestions don't help, but in my opinion, he first needs to get size 60 air jets and get his drill out. I have found it is much easier to drill new third party size 60 jets rather than soldering the original 115 jets.
I like that suggestion, especially knowing it's a tried and tested method. Before I go whaling on the jets I have, I'll order some #60's from PJ Motorsports and drill those out instead and take it from there.
The top end on this bike is an unknown to me, I've never ridden it. Great suggestions about replacing the mains, but I'll wait and see what gives when I finally get the old girl on the road. As for the carb synch, that's been done many times now (with varying degrees of success - largely down to poorly adjusted valves) but they're now pretty much dialled in, and always synched when the engine is as warm as I can get it simply by throttling it some up on the table. Ignition is stock.
If anyone who's ordered from PJ's before can send me a link to the air jet in particular I need that would be great (I know where it is in the carb, I just want to make sure I order the correct one). Thanks gents as always.
Send me your address and I will send you 4ea size 60 jets. You can send a PM if you like. I will even drill them for you if you like.
Outstanding, that's very kind of you indeed. The benevolence of strangers...there's nothing like it. I'll pm you nowcfairweather wrote: ↑Tue Nov 15, 2022 9:40 am Send me your address and I will send you 4ea size 60 jets. You can send a PM if you like. I will even drill them for you if you like.
- dontwantapickle
After the jet change, please report the results.
Absolutely I'll do that
And, if you haven't already - CHANGE YOUR BELTS!
Just to clarify,, the reason I don’t drill jets is because the size of the hole is just a small part of what meters the fuel. The length of that hole also has a large effect on fuel metering as does the surface finish, and the entry and exit corners of that hole.
This all is why Holley carb jets are sized by flow and not size, I believe Keihin jets are sized the same way but I am not positive of that, Holley jets I am. I do not drill jets, I also don’t use them from the cheap Chinese “eBay” rebuild kits. My .02
The pilot jets are air jets, not fuel and the air passes through those brass elbows into the carb. You could install the jet inside the rubber tubes and it would work the same because the jet only limits the amount of air entering the carb. Buying a high quality Kehin jet does not guarantee you have an accurate jet. I have measured Kehin jets that were way off from the stamped size, but they are usually correct. You can only be confident when you use a gauge to verify the size. One of the recommendations in the article is to use solder, which I don't personally like, but the goal was to close the hole and re-drill it to the smaller size. The shape of the jet is definitely changed with the solder, but it does not matter.
- 23 Replies
- 1048 Views
Last post by gltriker
- 12 Replies
- 675 Views
Last post by ISRAELI
- 20 Replies
- 1227 Views
Last post by theailer
- 4 Replies
- 343 Views
Last post by Recycled Roadkill
- 213 Views
Last post by 82aspy
