I'm getting the primary chain rattle type thingie on launch, and some rough going (under load) up to about 3k rpm. Much above 3k and things smooth out and run normally. It's a rocket (ok, not really, but she scoots like normal) again by 3500 rpm. Rolling at 2k or 2.5k rpm with traffic is smooth enough, though I can feel something amiss (a miss...) or "chuggy."
This is a new thing for the bike. There was no engine wrenching prior to noticing the issue. (I've been busy on other bikes - ones I'm not riding daily.)
Last week, I changed the oil and checked/adjusted valves (stone cold in the early AM). All were pretty close to spec - I adjusted a couple to bring them all to .006 but left most alone - and there was no issue in the oil change.
Also, fuel was really low around the time I noticed the issue, so I thought maybe I was having a bad gas scenario. (That's still possible.) I refilled (just under 5 gallons, so a pretty fresh tank) and added a bit more Seafoam than your standard maintenance amount - but not a bottle. About 50-75 miles later, it's still an issue. (No surprise, really.) It might actually be getting worse - creeping up above 3k rpm - but that's likely my imagination.
This AM, I decided to check the carb sync. (Why? Chain rattle behavior.) Things were not that far off, but I played a bit to get them closer to pulling the same vacuum as #3. (3 was low, 1 was high, 2 was a little high - but all right in the shop manual's definition of synced.)
I also noticed that exhaust header for #2 was cold-ish. OK. It was hot because it's in the sun, but it didn't get sizzling like #1, 3, 4 after a minute or so after start - at idle speeds. (OK. No fire or sporadic fire in the #2 hole!)
I pulled the plug. Nothing particularly odd there. I tested it, and I have consistent, good spark coming from the wire through the plug. The plug-to-wire connection seemed a bit sloppy, as compared to the fit on #4, but that's not new. Thinking maybe there's sporadic loss of spark due to vibration, I secured it a bit better.
Thoughts?
- Clogged jet that delivers fuel from idle up to about 3k in carb for #2?
- If so, Should I expect have to pull my carbs and inspect to have any hope of finding the issue?
- I'm 98% certain that the issue started about 5 days before I did the valve adjustment, but would an intake slightly too loose yield this behavior? - It's easier to check valves than to pull apart carbs, but easy-to-hard isn't always the best order of operation
- Would Seafoam even help clear a clogged idle or low rpm jet if I'm riding the bike well above 3k rpm?
- Maybe I put in a bit more Seafoam and gently ride in that sub 3k rpm zone for most of a tank - maybe that's a waste of time/effort/gas/Seafoam.
- And maybe I just bite the bullet and budget a couple hours to pull the rack, clean the jets in #2, and see if that solves things.
