Jardine 4 to 2/ 77 GL
Hi All - picked up a 77 with Jardine exhaust. Pipes are extremely blue. Does this suggest a rich condition? thxs kenai
2 - 1979 GL1000
1 - 1978
1 - 1977
1 for parts
1 - 1978
1 - 1977
1 for parts
- RIP: cookie
Re: Jardine 4 to 2/ 77 GL
Lean …
Gord(well, got that wrong !)Jones
Jardines are single wall pipes and do tend to blue very easily. I had a set on a very well tuned 78 and they were blued significantly after just a few months. Check you plugs and see what they say before digging in.
Blue makes them beautiful, so if your plugs are good you are golden.
In my experience blued single wall pipes are usually excessively rich while lean gives you a straw color, but imho nothing is absolute on pipe color.
I know from seeing many Keihin carb’d bikes ( g-wings, cb750’s, 1100’s etc and including Harleys) run on a dyno with a lambda sensor they all do the exact same thing with the stock Keihin’s. Very lean 15-16 to 1 a/f up to around 2000-2500 rpm (emission test point) at which point the secondary main comes In to play with the needle being raised out of the jet and the a/f ratio goes to somewhere between 10 - 12 to1,, pig rich ! Which is why you can add headers and such w/o worrying about jetting. That’s what I’ve actually seen !
This is a new bike and once it is started their is so much gas in the air your eyes water. Mass gas! Plugs were goopy definitely not lean and clean!
2 - 1979 GL1000
1 - 1978
1 - 1977
1 for parts
1 - 1978
1 - 1977
1 for parts
- 23 Replies
- 473 Views
Last post by iaven
- 159 Views
Last post by CYBORG
- 26 Replies
- 1550 Views
Last post by BlueThunder
