Faux tank gasket?
- Lead Member
Faux tank gasket?
So in painting my tank shelter, I tore up that seal for the clamshell halves. For the life of me I cannot find it anywhere, does anybody know the part number? Or how to deal with it? For now I just used window weather stripping, but looks kind of fugly in my opinion. for clarification, I'm talking about that seal that goes all the way around the locking parts of the shelter, not those little short pieces for the halves.
1980 gl1100 cafe, bobber, tracker thing
- Jonesz
Re: Faux tank gasket?
Might help if we knew the year etc.
Jonesz
1979 Suzuki GS850. Sold
- Lead Member
- Jonesz
So the partzilla fiche (fiches are invaluable info) I am thinking you are looking at item 16 part # 83127-463-000. The fiche is at:https://www.partzilla.com/catalog/honda ... ng/shelter
You might try entering that part # in Ebay? Just a suggestion.
Jonesz
- Lucien Harpress
If you can't find an OEM (probably rare) or a used (hard to remove without ruining) replacement, it may be worth finding the replacement frame with an intact seal instead. They probably come up a bit more often, and all you'd have to do is unbolt and transfer over all your shelter panels.
It's what I had to end up doing when I redid my 1200 Standard.
- Pony Ruiz
Or a new shelter.
If I recall right it was a pita to remove the frame from the abs sides. they were riveted on and a couple were very difficult to get to.
I think I'd go to another source and find some weather stripping that would work. Like maybe a sheet of something you could cut out the shape and stick (glue) it in there. You only see it when you are pumping gas. After awhile you won't see it - unless you want to. Been there done that more than once.
That said, there is still stuff that bugs me that I didn't get right, couldn't get right etc. etc.
1978GL1000 naked - kinda sadly gone. no bike at the moment.
"The greatest shortcoming of the human race is our inability to understand the exponential function." Albert A. Bartlett.
- 7 Replies
- 1227 Views
Last post by gargoyle
- 2 Replies
- 171 Views
Last post by wingrider
- 8 Replies
- 1111 Views
Last post by ivanljungdahl
- 0 Replies
- 139 Views
Last post by GENERALWON
