Zinc oil additive.
Gowing
Zinc oil additive.
Post by Gowing »
Last week changed the oil in 75. I added approx. 3 oz of risilone zinc additive. Took 8 mile quick trip and froze my hands. When I got home I had a tough time finding neutral. That has never happened before. Dumped that oil out. Be careful when adding un necessary stuff.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
5speed
Re: Zinc oil additive.
Post by 5speed »
I use rotella T4 oil..it has zinc in it.
Most of those zinc additives say on the bottle not use with a wet clutch.
BlueThunder
Post by BlueThunder »
robin1731 wrote: Thu Nov 26, 2020 6:32 pm Most of those zinc additives say on the bottle not use with a wet clutch.
Yes, you have to be careful with a wet clutch. Synthetic oils often do the same thing. At the risk of another dead kitten, use Castrol 20W50 T4 (for motorcycles) and you'll be fine. In fact, Bob will be your uncle! lolol
...Brian
1977 GL1000 - Ox
Old Fogey
Post by Old Fogey »
Yeah, zinc is great for reducing wear on flat tappet or rocker cams, not so much for clutch plates!
redglbx
Post by redglbx »
My .02, any additives are a bad idea generally for a wet clutch or a starter clutch, just not a good idea.
As a side note, I have used only synthetic based car oil in my 76 since around 1980, usually Mobil1 15w-50 or Rotella .
5speed
Post by 5speed »
Old Fogey wrote: Fri Nov 27, 2020 9:22 am Yeah, zinc is great for reducing wear on flat tappet or rocker cams, not so much for clutch plates!
This is what mobil 1 synthetic does to lifters and camshafts. :(
lifters 002.jpg (114.92 KiB) Viewed 359 times
redglbx
Post by redglbx »
5speed wrote: Fri Nov 27, 2020 9:55 am
Bull !
Uh oh! A squabble is a brewing. :shock:
Everybody hide the kittens!! :oldies
Cliff (74yrs ;) )
Sidecar Bob
Post by Sidecar Bob »
BlueThunder wrote: Thu Nov 26, 2020 9:18 pm ... use Castrol 20W50 T4 (for motorcycles) and you'll be fine. In fact, Bob will be your uncle! lolol
I didn't even know I was auditioning new nephews....... :lol: :roll:
FWIW, I tried Rotella T4 (15W40 only) back when it was just called Rotella T and didn't like the way it worked in either of my bikes, even in the 'Wing in hot weather so I changed to T6 (synthetic 5W40) in the winter machine (expensive but it allowed easy starting after sitting outside at work all day in -30c) and Castrol 4 stroke (now called "4T") in the 'Wing.
Since I retired and the winter machine no longer sits outside for hours every day I changed to the Castrol for it too, although this year I bought Motomaster (Canadian Tire house brand) because they were sold out of the less expensive Castrol.
Note that Castrol makes both "4T" conventional motorcycle oil and "T4" synthetic motorcycle oil for more than double the price. I think they do things like this to confuse people.....
BlueThunder
I stand corrected.... I meant Castrol 20W50 4T - Motorcycle Oil
...Brian
1977 GL1000 - Ox
Sidecar Bob
Why 20W50? Honda specified 10W40 and I found that even in hot weather 15W40 made shifting harder.....
tory
Post by tory »
Sidecar Bob wrote: Wed Dec 02, 2020 1:09 pm Why 20W50? Honda specified 10W40 and I found that even in hot weather 15W40 made shifting harder.....
I've noticed same thing.
1978 GL1000
1986 GL1200 Aspencade
With California Sidecar
1965 CA95 Benly
taunusrainer
Post by taunusrainer »
I use this fluid in my 1000 for decades. No clutch/shift/starter issues.
This kind of MoS2 addtives were first used in aircraft engines in ww2. Even without oil pressure the engine would still run half an hour.
Sidecar Bob
I used to use oil & fuel additives too but I eventually figured out that modern fuel & oil don't need them.
