starter rebuild maybe?
the starter on my 1100 started acting up last fall. It would click but not roll the engine over occasionally. (strong battery, clean connections.)
It's also making a wirring (hi tech diagnose here. lol) like the starter drive isn't disengaging.
Is it time for a rebuild or just a good cleaning?
Re: starter rebuild maybe?
try cleaning. also make sure there is a good ground connection. Make sure to use two wrenches to remove the positive connection on the starter
I like that suggestion Doc..doesn't cost as much.
The carbon buildup inside makes them weak especially when hot.
And make sure the commutator is clean and the carbon from between contacts is brushed out. Also repack the gear reduction (don't loose anything including the shims).
I did the same thing, I rebuilt a lot of starters and alternators, even AC compressors back in the day that's what you did at the GM dealer before everything was an assembly replacement, but anyway I found out that thing didn't want to come apart very easy stuck with some kind of whatever they use, then trying to finesse it back exactly to get a just-right was a challenge, cleaned and Polished everything Lube is always important to lube Lube keep moving anyway damn thing worked out good it can be done
76 gl naked, runs good, always tinkering
79 gl all the fairing stuff gone, work-in-progress
68 chevelle hi compression fat block, OH YA! In process of changing gear ratios, I'm excited!
73 tahiti jet 455 olds sweet heart, sad in a way, she gone, traded for a VTX Honda, didn't like it , traded For a Harley 19 Road King Classic, Stage 2, OH YA
boogie..I'm with you. rebuilt many a starter and alternator when I was a poor teenager that couldn't afford a rebuilt one..
even swapped the factory alternator in my volvo for a gm one because brushes for the volvo one were $75..and that was in 1981..
Hey 5-speed, that's very cool man, did very similar, in 81 I was turning wrenches at Oldsmobile, attention to detail, everything we built was better than anything you could buy reman!
I kept everything running around here picking from a little junk oh, oops I mean Salvage LOL yard behind my shop that I built up from scrapping! anyway good stuff, keep it up, love stories, life is good
In case you didn't already know, unlike car starter motors, this one doesn't have a Bendix drive or anything else similar. The starter motor is only a motor and a gear train, coupled to the engine by a starter clutch inside the engine that is a one way device that only engages when the starter motor is turning faster than the engine.5speed wrote:It's also making a wirring (hi tech diagnose here. lol) like the starter drive isn't disengaging.
If you press the start button and hear a whir before the engine is turned by the motor (or instead of the motor turning the engine) the starter clutch is not engaging properly and needs to be addressed before permanent damage occurs.
I don't know what would cause a whir after the engine starts.
- jdvorchak
The only thing I can think of why the whir sound after engine start is the solenoid or start button is sticking ON. Both are easily cleaned with lacquer thinner or electrical contact cleaner. DO NOT USE WD-40 on electrical contacts.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- Rednaxs60
Rebuilt the starter on my '85 three years ago after the new replacement crapped out. Good info on the forums regarding this. Found a lot of brush dust inside:
Got replacement brushes from a local alt shop. Once cleaned up worked a treat. When/if you take the starter apart, there is a locating dowel, very small that can come out. Be careful not to lose: Took the starter completely apart and cleaned, still working well."When writing the Story of your life, don't let anyone else hold the pen."
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2021 Royal Enfield Himalayan
2008 GL1800 (sold)
Ernest
2008 GL1800 (sold)
I'd be very careful using something as flammable as lacquer thinner to clean something where sparks may occur, not to mention that it can dissolve some plastics. Far better to invest in proper electrical contact cleaner.
My experience has been that Staters make whir, hum noises, sometimes, a lot of times they're just noisy and will calm down once to charge rate stabilizes, are the times there's a problem rutro, yeah that started Drive is one way roller clutch, they have similar in automatic transmissions, of course if that thing's got a problem then you got to pull the engine back cover off yeehaw
thank you for the tip. the starter is on the list for today or tomorrow.Rednaxs60 wrote:Rebuilt the starter on my '85 three years ago after the new replacement crapped out. Good info on the forums regarding this. Found a lot of brush dust inside:20170112_201801.jpgGot replacement brushes from a local alt shop. Once cleaned up worked a treat. When/if you take the starter apart, there is a locating dowel, very small that can come out. Be careful not to lose:Starter Driving Gears - 1.jpgTook the starter completely apart and cleaned, still working well.
- 14 Replies
- 736 Views
Last post by ritalz
- 3 Replies
- 504 Views
Last post by 5speed
- 4 Replies
- 511 Views
Last post by CYBORG
- 584 Views
Last post by Sidecar Bob
