Help Reading Plugs
- Lucien Harpress
Help Reading Plugs
Hey, all.
I was wondering if I could get a second (third, fourth, etc.) opinion on what I'm looking at with these plugs. They're out of my KZ, and were pulled right after about a half hour of.... "spirited" riding. I've got an idea of what I'm looking at, but more eyes couldn't hurt.
What's going on here?
(If you right-click on each picture and select "View Image", you can get a rather much larger version of each.)
Re: Help Reading Plugs
Looks pretty good to me. Ride that thing like you stole it and quit worrying about it.
- Lucien Harpress
I would love to.
IF it weren't still randomly dropping cylinders, and this wasn't the second time I'd chipped an insulator on cylinder 3.
Went back and zoomed in on the top left plug. Looks like some insulator damage there. Don't know if that happened before the plug went in, but it worse case it may be pre-ignition. Run 87 octane. And ride it like you stole it.
For best plug readings you need to look down inside where the insulator is. Takes a magnifying glass and extra light. For the most part those do look good. But yeah, the broken porcelain may be from detonation. You could see that better by looking down inside the plug too.
What octane are you running?
- Lucien Harpress
Currently running standard 87 octane, same as the rest of my bikes. The only difference I can figure with cylinder 3 specifically is that it does have slightly higher compression than the other cylinders (low 120s vs, 115-117 for the rest), but the "usable compression range" in the manual is 119-171.
But I'm doing that thing where I'm chasing problems in circles again without much to show for it.
Try running some 93, or whatever your premium is, and see what it does.
- Lucien Harpress
Ran about an hour's worth of 93 octane, and while it seemed to help the top end a bit (as far as I could tell on the ol' butt dyno), it didn't change anything about the bottom end- pops out the exhaust throughout pretty much the entire rev range (although it MIGHT'VE cleared up a bit near redline? Can't be sure), and lots when it came to deceleration (the bike has air cutoff valves, but it didn't sound like it).
Except the problem DID switch sides. Because this bike is haunted. Or messing with me. Or both.
In any case, the original question has been answered. If (when) I've got any further issues, I'll put it in an appropriate thread. Thanks.
- Lead Member
Is it me or are they the wrong plugs aren't they meant to be D8EA or equivalent.
They are out of his KZ1300.Tom61 wrote:Is it me or are they the wrong plugs aren't they meant to be D8EA or equivalent.
- 8 Replies
- 843 Views
Last post by Jimtt
- 18 Replies
- 3449 Views
Last post by 83Interstate
- 13 Replies
- 362 Views
Last post by lcallison
