Track T 2411 wrote:As the 'Red Page' says, the ComStar wheels were introduced for the '78 model year. As for tubes and tubeless, I'm wondering if the tubeless tires of the time didn't have the appropriate weight ratings for the GoldWing...
I don't think it was the weight cause from what I've read a CBX weighed 600 lbs with a full tank of gas.
Thanks for the info! I have an extra set of spoke wheels I might put on this one. I usually like spokes better, but these comstars work well with the look of this bike.
I still haven't done a follow up compression test because the oil was pretty sludgy, and I want to change it before I do anything else, and I had to mail order a filter.
I'm going to do belts, water pump, valve adjust, timing, plugs, filters, clean the carbs, and run it.
Here's what I've found so far,
The good: Dyna ignition, full floating rear disc, Wat Yong coils
The bad: One leaky carb, antifreeze at the weep hole, and some hacked wiring (already fixed the wiring issues)
