suggestions
- Lead Member
suggestions
gday folks, am new to forums and not quite sure what im doing??? own a 1976 sulfur yellow GL1000. love it! also working on a 1980 GL1100. both American imports to the UK. Am removing the engine from the 1100 to sort out starter clutch, any suggestions on what else i should do whilst the engine is out? Regards to you all, John.
Re: suggestions
Welcome from Wisconsin, U.S.A. A good starting point for you might be the new2 you thread. There's a link to it in my signature. Dig in, and feel free to ask questions! Enjoy the ride!
- RIP: cookie
Re: suggestions
Welcome to the 'Wingdom ....
Neutral switch is much easier with the engine on the bench ....
- 77Gowing
Re: suggestions
This forum and shop talk will be your best friend.
Oh yeah Welcome. Best of luck on your projects.
"Less is More" Anonymous
77Gowing
2014 Yamaha 950 V Star (sold)
77Gowing
Re: suggestions
What is going on with the starter clutch?
Problems with it, like intermittent free spinning and a huge clatter when it stops, often only means you're using the wrong type of oil.
Re: suggestions
really? huh.Explorer wrote:What is going on with the starter clutch?
H2G2=42
H2G2=42
Re: suggestions
Well actually yeah, mine quit as soon as I started using the Delo 400 and that was a suggestion from someone else who'd had the same experience.
- Old Fogey
Re: suggestions
Some tips on the starter clutch service: http://wingovations.com/slipping-starte ... 4579471093
Pull the crankcase filter (4 bolt oblong shaped plate, bottom right side of engine.) With it off, flush through with some fuel.
Since you are already going into the rear case, pull the clutch plates and inspect them for wear and warp. Change the starter chain; they can and do break and make a mess. Depending how deep you want to go, this might be a good idea too:
http://wingovations.com/scavenge-pump-p ... 4579471109
Good time to take the starter off and give a service too. Check the stator for any signs of frayed or cracked wiring and signs of burning. Take the water pump outlet off and check the impellor for any signs of sideways movement. Any movement at all, change the pump.
- killswitch
Re: suggestions
Thanks for this info. Top of task list as the clutch keeps spinning on cold starts.Old Fogey wrote:Some tips on the starter clutch service: http://wingovations.com/slipping-starte ... 4579471093
Merry Christmas all.
Re: suggestions
If the starter comes out, be sure to disassembly and clean the carbon out. The carbon, when hot, steals voltage and results in slow cranking only when hot. So get it clean when it is out because that is easy to do.
Re: suggestions
mine does the intermittent Whirrrrr on start up and been doing it through all sorts of types of oil and for decades
Re: suggestions
Mostly when it's cold? Outside temps cold, not the engine.rcmatt007 wrote:mine does the intermittent Whirrrrr on start up and been doing it through all sorts of types of oil and for decades
Re: suggestions
consistently when I stop for gas and there are other bike brands also at the station. Also when it has sat a LOT.
- Lucien Harpress
Re: suggestions
Most of the bikes I've owned have had similar issues with the starter clutch failing to catch on REALLY cold days (Michigan winters, mostly). I'm assuming it's an oil thing, because it goes away once the bike is warmed up a bit. Starting with a fresh oil change might help/eliminate that problem. (I can't make any recommendations, because that's outside the scope of my expertise AND probably outside of the scope of this thread.)
Re: suggestions
I agree. only seems to happen in colder weather. and with winter layups. I start mine up every week during the winter, and usually warm the shop up before I do it. Every now and then it sticks. But usually catches on the second try. Hitting the starter button just as the clutch starts to stop spinning, seems to help it catch
- 13 Replies
- 574 Views
Last post by Rat
- 11 Replies
- 502 Views
Last post by cmyoch
- 212 Views
Last post by CYBORG
- 6 Replies
- 245 Views
Last post by bladredhead
