Rectifier question
- Lead Member
Rectifier question
So my 79 GL isn't charging, I've read what and how to test but am stuck at work all day so it'll have to wait. The question I have is when I unhooked the connector with the 3 yellow wires as the bike was running there was a noticeable change in the idle, is that normal or could it be an indication of something wrong with the stator? I guess getting the ol' multimeter out tonight will answer any questions I may have, but it's slow at work and I'm bored lol. I was just surprised that unplugging that connector had an effect on the idle is all.
"There must be a beginning of any great matter, but the continuing unto the end until it be thoroughly finished yields the true glory"
Re: Rectifier question
First, Welcome from Wisconsin! I noticed that same 'symptom' when I was working on my 1100I. I've since put over 15k miles on it with no related electrical issues, so unless someone else chimes in to the contrary, I wouldn't worry about it (I did cut out the white connector and solder the three yellow wires...).
I had also noticed how much the engine idle speed on my '75 increased when I disconnected the 3 yellow wires connector to see what the AC outputs were, after installing a new stator.
Cliff (74yrs )
- Lead Member
Well, went home for lunch and decided that the bike was more important than food. Fired up the bike after charging the brand new battery overnight, and lo and behold it seems to be charging just fine sitting at high 12 to low 13 volts when idling all the way up to mid 14's at about 3000 rpm. Now when I switched to AC to check voltage at the connector with the 3 yellow wires is where it gets interesting, everything I've read online says normal output should be about 40-50 volts, well I was getting like 88 on two of them and 90 on one of them. I checked more than once and should've taken a picture, but that seems a tad high to me. I'm wondering now if I don't have something drawing power somewhere like a short, a bad ground or if I just need to take the bike for a ride on the highway and see what it does afterwards. As of right now I've never been the road with it, just been working the kinks out after it sat for 3 years without hitting the road. I should've checked it last night when the gauge wouldn't read over 11 volts even sitting at 3000 rpm.
Does it need a new battery? Oops. Went back and read your first post...
Again.
How many RPMs was the engine running at when the disconnected three yellow wires AC volt readings were extremely high?
I saw readings across the tested legs near 90 Vac when my engine was reving up over 5,000 rpm.
According to a very trustworthy and reliable source of information, it was stated that those very high AC readings are normal , at much higher rpms than the testing would normally be performed at.
Mid 14 vdc at 3000 rpm is excellent!
Yes! By all means ride the bike now and worry less about battery charging system.
Again.
Cliff (74yrs )
- Lead Member
I really do need to get the old girl on the road, she deserves better than sitting for the past 3 years!gltriker wrote:Does it need a new battery? Oops. Went back and read your first post...
Again.
The high readings were at idle surprisingly, but I'll check what they are at about 3000 or so when I get home. This whole thing could be "user error" as starting it and letting it idle a LOT this past weekend could easily be my issue. I bet I fired that thing up 10+ times without going anywhere lol. Time to get on the highway and blow the cobwebs out of it!
If something was drawing extra power the voltage would decrease, not increase.
I cannot find anything in the GL1000 FSM about unplugging the alternator from the bike to measure the voltage but based on what I have seen & read elsewhere I would expect something in the 90V range (I saw a pic once of someone checking a bike's stator with 240V light bulbs and I doubt they would be very bright with 50V).
RE RPM increase when the stator is unplugged: As you probably already know, most bikes (including Classic 'Wings) have alternators consisting of a rotor (usually permanent magnets in the flywheel) and fixed generating coils (stator). Since the magnets always have the same field strength, the stator's output is always the same for a given RPM. The output voltage is regulated by shunting the excess to ground with a zener diode or equivalent circuitry in the regulator/rectifier.
That means that a fair bit of electrical power is being produced and used (either by the lighting, ignition &c or by the regulator shunting it) all the time. The alternator doesn't produce that power out of thin air but converts mechanical power into electrical power, which means that it probably takes somewhere in the area of 5-10 HP to turn it.
When you unplug the stator there is no electrical load on it so the mechanical load becomes very small. It would be more surprising if the engine RPM didn't increase.
Bob said exactly what I was thinking and wanted to say. Only I didn't know the "5-10 HP" part of it.Sidecar Bob wrote:If something was drawing extra power the voltage would decrease, not increase.
H2G2=42
H2G2=42
I knew it was a substantial amount but I had to look up how much. Note that I said "probably because 5-10 HP is an estimate based on the info I found in several places online.
So.....if somebody wants to drag race you and your GL, after verifying your battery is FULLY CHARGED, unplug the three AC
wires connector and pull all unnecessary circuits' fuses, first!
Cliff (74yrs )
That's why racing machines usually don't have alternators...
- 1983lux
My bike never really charged right until I upgraded to a modern regulator/rectifier. I'm no expert but I think i've heard that your bike's wiring has to be perfect for the old system to work right, and with a 40 year old harness this is somewhat unlikely.
I got one from a cbr 600, cut the plugs off it and wired my plug from the old gl1000 one on to it. Only cost me about $35 cdn. This may not be the cause of your issue but something to consider.
details here: http://wingovations.com/regulator-rectifier/4579471117
1975 Honda GL1000 - Naked
Motor from 1979 Model
1975 Cams and Carbs
Dyna S Ignition
1975 Cams and Carbs
Dyna S Ignition
You could also use the regulator/rectifier from an '80 or newer GoldWing (or any other Honda with permanent magnet alternator). Or if you want a real improvement you could upgrade to a MOSFET reg/rec (apparently they don't regulate by loading the alternator).
- 475 Views
Last post by cbrianroll
- 15 Replies
- 965 Views
Last post by Gowing
- 37 Replies
- 845 Views
Last post by maury
- 3 Replies
- 216 Views
Last post by Placerville
- 9 Replies
- 404 Views
Last post by Recycled Roadkill
