C5 ignition
millerdog
C5 ignition
Post by millerdog »
Just wond ring if any one who has installed one of thes has had high rpm breaking up. Like 6 grand and up, and if so whether you found any solution to it. I’ve been playing around with different plug gaps, and have made some positive progress but I still can’t get to put to redline.?
Re: C5 ignition
Mine does around 8500. It should have been shifted to the next gear anyways. Tried different carburetor and it still does it. Gary from PowerSrc thinks it is lean.
Others have found they need a direct source to battery power. Ignition triggers a relay which connects to a 12 volt source to battery.
Re: C5 ignition
Just read other post. Sounds like you’ve done this.
Re: C5 ignition
If the C5 fellow suspects a lean condition is limiting the engine RPMS, I'd try pulling the choke button out a small distance to enrichen the carburetors .
Cliff (74yrs ;) )
millerdog
Re: C5 ignition
Post by millerdog »
ericheath wrote:Mine does around 8500. It should have been shifted to the next gear anyways. Tried different carburetor and it still does it. Gary from PowerSrc thinks it is lean.
What plug gap did you end up with. The directions say to go with the smallest gap possible. I’m at .015 right now.
77Gowing
Re: C5 ignition
Post by 77Gowing »
No probs with my C5. I don't recall having any type of problem with install and with use. Sorry but I don't remember anything particular except that I like it and is relyable
"Less is More" Anonymous
77Gowing
2014 Yamaha 950 V Star (sold)
Re: C5 ignition
77Gowing wrote:No probs with my C5. I don't recall having any type of problem with install and with use. Sorry but I don't remember anything particular except that I like it and is relyable
I consider the install, and setup, even easier then the Dyna, and even the original points system. Have never had a problem , or had to adjust mine, since the day I installed it.
Re: C5 ignition
I went down to 0.22 but I’m back to 0.28 I think. Mine is great until about 8500 which is well past the redline on the 1200.
Have you tried the four different settings?
Have you checked to see that it is still timed correctly. If it’s firing too early, it could end up badly.
Nothing easier than C5 to check as far as timing goes.
millerdog
Re: C5 ignition
Post by millerdog »
I’ll check the timing again. Not really Ute what’s going on.
millerdog
Re: C5 ignition
Post by millerdog »
If I run my plug gap at .028, it barely reaches 6 grand.
millerdog
Re: C5 ignition
Post by millerdog »
Could be a carb problem. Backfires out the left side pretty bad on deceleration, and a little most other times. Except acceleration.
millerdog
Re: C5 ignition
Post by millerdog »
WellIve tried everything. I gues I’m gonna start from scratch and solder all my connections. Even if I don’t think that’s the problem. I’ve used high quality weatherproof connections on the entire thing. I can’t find any power leaks, and all the grounds are clean and tight. Back to the drawing board I guess. Might just end up putting a Dyna back on it. At least I could ride.
SnoBrdr
Re: C5 ignition
Post by SnoBrdr »
millerdog wrote:WellIve tried everything. I gues I’m gonna start from scratch and solder all my connections. Even if I don’t think that’s the problem. I’ve used high quality weatherproof connections on the entire thing. I can’t find any power leaks, and all the grounds are clean and tight. Back to the drawing board I guess. Might just end up putting a Dyna back on it. At least I could ride.
Have you spoken with Paul?
Was very helpful installing mine.
78 GL1000 Original Owner 131k
Re: C5 ignition
millerdog wrote:Could be a carb problem.e Backfires out the left side pretty bad on deceleration, and a little most other times. Except acceleration.
quote="millerdog"]Could be a carb problem.
Cliff (74yrs ;) )
77Gowing
Re: C5 ignition
Post by 77Gowing »
Yes, Paul is very helpful
77Gowing
