No starter after coil install
- tlbranth
Re: No starter after coil install
I'm going to try and help you out here. I'm going by a '75 wiring diagram which I believe is the same as yours.
Power to the coils is via white/black wires - not black. Check that. One w/b has a double bullet connector with 2 w/b wires coming out of it that go to the coils.
With the right handlebar switch set to 'run' and the ignition switch turned on, read the voltage between the b/w connector and ground. Tell me what you get for a reading.
I believe you have something connected incorrectly to your kill switch. The connectors are brown/black to brown/black and the aforementioned white/black connected as described above.
Let me know what you find.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- cmyoch
Sorry, Memorial Day weekend took over and I just now got back to the internet. I will run your test and report back.
1976 GL1000
1978 Yamaha XS650
1984 Harley Davidson XLH1000
1969 Camaro Z28
1977 Redheaded Wife (Better move her to the top of this list)
1978 Yamaha XS650
1969 Camaro Z28
- cmyoch
At home now taking a look and I forgot that I blew a main fuse the other day when I was messing around. It was my own fault but now I need to hunt down a blade fuse around here somewhere so I can test.
1976 GL1000
1978 Yamaha XS650
1969 Camaro Z28
1978 Yamaha XS650
1969 Camaro Z28
- cmyoch
tlbranth wrote:I'm going to try and help you out here. I'm going by a '75 wiring diagram which I believe is the same as yours.
Replaced the fuse and tested. There is 11V from the powered switch in the “run” position to the first connector in the harness. I show zero power to the double female connector. There must be a break or disconnect in the white/back wire in between. I will pull the false tank and air box again to find the issue.
1976 GL1000
1978 Yamaha XS650
1969 Camaro Z28
1978 Yamaha XS650
1969 Camaro Z28
Please. Take a few detailed snaps of your Dyna coils' installation(, as it presently exists,) after you get the area exposed again, cmyoch.
Confucius? say*...A picture is worth a thousand words.
Respectfully, we're getting close enough to a thousand words. Maybe two thousand.
Now, We need a photo or two to examine your work.
*not worth debating the source
Cliff (74yrs )
If you had utilized the linked topic found at the bottom of this page in Similar Topics to install your Dyna coils, although it shows the GL1000 factory schematic correct primary wires colors, there is a glaring wiring terminal identification error in post#5.
The double female terminal on the black/white wire, which the author identified as G, is NOT a ground connector.
That double female terminal wire comes from the Engine Stop Switch and powers the 2 individual black/white wires to both coils.
See here:
viewtopic.php?f=1&t=36013
See here:
Honda's convention is black for general ignition-switched power, which feeds one side of the ballast resistor; black with brown stripe for power from the ballast to the kill switch; black with white stripe for power from the kill switch to the coils; and green for ground. If it's connected any other way, there's been some molestation and you need to figure out what.
The Dyna (or points) goes in the circuit on the other side of the coils to complete the circuit to ground: the blue and yellow wires. Even if the Dyna was disconnected, there would be 12v power at the black/white wire if it's all connected right otherwise, and the kill switch is on.
- cmyoch
Okay, I dug in and scoped it out. Powered black/white wire to the double female connector with both black wires from each coil connected to it. Yellow to yellow and blue to blue from each coil to the harness. Black/brown and black from the resistor to the same connections in the harness.
I will buy a test light tomorrow and check continuity from the powered "run" wire through the double connector.
- Wires from the handlebar switch
- MVIMG_20190530_212512.jpg (95.55 KiB) Viewed 210 times
- Single black/white wire to double connector.
- MVIMG_20190530_212428.jpg (92.29 KiB) Viewed 210 times
- Ballast resistor wires
- MVIMG_20190530_212410.jpg (84.17 KiB) Viewed 210 times
1976 GL1000
1978 Yamaha XS650
1969 Camaro Z28
1978 Yamaha XS650
1969 Camaro Z28
It's encouraging to see your original wiring colors aren't dirty and faded.
Fully charge the bike's battery, too.
12 volts is a very weak state of charge. Very. Weak.
Cliff (74yrs )
- cmyoch
The battery is about 4 months old but needs to be on a trickle charger.gltriker wrote:It's encouraging to see your original wiring colors aren't dirty and faded.
1976 GL1000
1978 Yamaha XS650
1969 Camaro Z28
1978 Yamaha XS650
1969 Camaro Z28
- cmyoch
Does the ballast resistor bracket need to be grounded? At the moment, I have it zip tied to the frame because I could not get it mounted to the new coils.
1976 GL1000
1978 Yamaha XS650
1969 Camaro Z28
1978 Yamaha XS650
1969 Camaro Z28
No. Stop guessing. No ground connection is required on the positive side of the ignition primary circuit wiring.
Was this engine actually starting and running correctly before changing the ignition coils?
Were any wiring connectors in that bundle of 5 wires you are presenting in your fingers, disconnected and reconnected while you were working?
Did you replace the right handlebar switch?
I inquire because the new OEM Honda right side handlebar switch I installed on my trike 2 years ago, had two individual wire colors that didn't match up with the original 1975 OEM factory wire harness colors.
Utilizing the factory wiring schematic found in ShopTalk (thanks Sidecar Bob!) and a multi-meter, I sorted which which was which. Or, more fittingly, which switch was which.
No, I didn't guess.
No, I didn't guess.
Cliff (74yrs )
- cmyoch
Yes, everything was in working order before disassembly. That is what has me totally perplexed! I pulled the shelter off, pulled the air box, disconnected the primary and secondary coil wiring, replaced with new coils and hooked everything back up the way it disconnected.
I'm going to have to chase connections with a meter I guess. I hate electrical!!
1976 GL1000
1978 Yamaha XS650
1969 Camaro Z28
1978 Yamaha XS650
1969 Camaro Z28
"I'm going to have to chase connections with a meter I guess."
No guessing!
Go back and read tlbranth's post #16.
It's a good bet at least 2 right side handlebar switch wires are mismatched. Another thought. ...
Although, we haven't asked the question, you haven't stated whether the headlight is operating correctly, when the key switch, itself, is turned on.
The right handlebar switch harness are all positive wires.
Before you go any further, for safety sake while you work, lift the rear tire completely off the floor, and be sure the transmission in neutral.
Done.
No guessing!
Done.
Cliff (74yrs )
- cmyoch
gltriker wrote:"I'm going to have to chase connections with a meter I guess."
No guessing!
True, no guessing. I was really hoping I was missing something obvious to avoid having to chase wiring.
1976 GL1000
1978 Yamaha XS650
1969 Camaro Z28
1978 Yamaha XS650
1969 Camaro Z28
- 8 Replies
- 288 Views
Last post by Shadow
- 10 Replies
- 514 Views
Last post by Sidecar Bob
- 10 Replies
- 1300 Views
Last post by medlinaround
- 208 Views
Last post by ericheath
