We all know the problem with dirty contacts with the neutral light switch. The neutral light will not go fully out - kinda of a low glow no matter what gear one was in. Or the neutral light would not even light. The source of the problem is that the switch contacts are in oil and with time, oxidize or engine deposits "gunk" on them, rendering the faulty operation of the neutral light.
The real problem is that replacing the neutral light switch is a major pain in the butt. Prying the front of the motor up to remove the defective switch was simply not worth it. In my case, the task was relegated to the bottom of my maintenance list with priority lower than low. I figured it would be replaced when I pulled the motor.
I realize that a kitten may die but I only use Castrol motorcycle oil (20W50). Been using only Castrol since the my first bike (CB360T) in 1976. Without sounding like a commercial, I personally believe that this oil is the best especially for air cooled motors. Why do I mention this? Well, Castrol is a detergent oil in which engine deposits are "cleaned". After using this oil in my GL1000 for two years, the neutral light functions correctly! The neutral light illuminates when it should and extinguishes when it should. That is, the dirty contacts have been "cleaned".
Just throwing it out there for those whose neutral light switches don't work correctly. I can now remove this low priority item from the maintenance list.
Neutral Light Switch - Well, Well, Well
- BlueThunder
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
Re: Neutral Light Switch - Well, Well, Well
Aren't you glad you never got to that task?
- BlueThunder
desertrefugee wrote:Aren't you glad you never got to that task?
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
not denigrating your use of Castrol, I've had good luck for the same issue with a thorough diesel flush. then I only run Rotella.
but YMMV.
but YMMV.
H2G2=42
H2G2=42
- Lucien Harpress
My neutral light is something I've just decided to live with, but I'm also getting the impression a clutch job is in my future.
I realize both of these are jobs that I can do with the engine in, but after doing a frame-down restoration of a CB750, pulling the engine on the 'wing doesn't seem too bad.
Besides, it needs some paint anyway.
- flyday58
I'll second that emotion, I've had the motor out of my 750 five or six times in the last year and a half for various reasons. Takes longer to get the jack in the best position than most everything else. As for the neutral switch, I went ahead and dove in on the 76 LTD and got it done. It wasn't horrible, just getting your jaw set in the right position to get at the screws. I guess it's gonna be the same getting at the water pump cover JAS screw on the upper left corner. That's for another day.Lucien Harpress wrote: I realize both of these are jobs that I can do with the engine in, but after doing a frame-down restoration of a CB750, pulling the engine on the 'wing doesn't seem too bad.
2005 BMW R1200GS
2008 BMW R1200RT
1988 Honda XR600R
1974 Yamaha GT80
2008 BMW R1200RT
1988 Honda XR600R
1974 Yamaha GT80
- 1 Replies
- 308 Views
Last post by Steevensi
- 19 Replies
- 1584 Views
Last post by Whiskerfish
- 3 Replies
- 277 Views
Last post by Track T 2411
- 8 Replies
- 401 Views
Last post by redglbx
