1976 gl1000 clutch lifter arm return spring.
- Tbell
Removed clutch cover to adjust the clutch cable and discovered the lifter return spring laying loose in the housing. Just wondering what the symptoms would be with this spring not connected???
Tom
Connoisseur of fine wings
76 Yellow gl1000 Total rebuild
93 Black gl1500
2004 NRX1800 Black Cherry Rune
Having enemies is not necessarily a bad thing! It means that at some point in your life you have stood up for something.
93 Black gl1500
- Old Fogey
Re: 1976 gl1000 clutch lifter arm return spring.
Only thing I can think of is a possibility of the cable slipping out of the arm.
