Unpredictable water pump
- Zinc Member
Hello all;
In the almost 20 years that I've owned my '76 GL, the pump has caused me much head scratching, probably why I've got no hair left.
Every so often, I'll find drops of water, oil or both under the bike out of the pump, but it bears no relation to whether I've just used it, parked it for a month, what the season is or anything. In fact it can go for years without any sign of leaking; to be honest I've got so curious (paranoid?) about this that I check most days - there is simply no pattern to this. (Yes the weep hole is clear and no signs of water in oil and vice versa).
So I suppose my question is, am I safe to keep riding it unless it gets worse or is it at risk of sudden failure?
Cheers,
Pete
Cheers,
Pete
1976 GL1000 K1 19,006 miles
- desertrefugee
Re: Unpredictable water pump
I don't know that I have ever known of a water pump - car or motorcycle - failing catastrophically to the point where it wouldn't actually pump. The typical failure modes are bearing squeal and/or leakage. If I were you I wouldn't sweat it. In fact, I have a 78 GL 1000 that behaves very similarly!
... and I'm not sweating it.
- Zinc Member
Thank you sir, I was hoping that someone would say that - it leaves me free to worry about something else...desertrefugee wrote:I don't know that I have ever known of a water pump - car or motorcycle - failing catastrophically to the point where it wouldn't actually pump. The typical failure modes are bearing squeal and/or leakage. If I were you I wouldn't sweat it. In fact, I have a 78 GL 1000 that behaves very similarly!
I have one that has been leaking intermittently for years. The thing is that this bike seldoms leave home town so it is not a concern. On my "over the road" bike I would change it out.
Here is some catastrophic water pump failure for you.desertrefugee wrote:I don't know that I have ever known of a water pump - car or motorcycle - failing catastrophically to the point where it wouldn't actually pump. The typical failure modes are bearing squeal and/or leakage. If I were you I wouldn't sweat it. In fact, I have a 78 GL 1000 that behaves very similarly!
When it started to squeal it sounded like it was coming from the transmission. It squealed for about 2 or 3 minutes then stopped which made me think it was the throw out bearing. I decided if it started again I would find a garage and have it checked.
It started squealing on the highway then I lost my power steering. I got off the highway as soon as I could, opened the hood and the water pump pulley was sitting on the shaft leaning against the rad.
No lkeaks from the weep hole, no prior indications there was a problem. The pump wasn't that old either.
- 13920473_10153979374335817_1429285351754111070_o (1).jpg (92.89 KiB) Viewed 149 times
- desertrefugee
Yikes! Somehow I knew that one of our fun members would come up with a catastrophic failure. And even less surprised it was you 5speed!
... Must have been a Ford.
With regards to the intermittently dripping GL water pump, I don't think there's any looming emergency.
I void warranties.desertrefugee wrote:Yikes! Somehow I knew that one of our fun members would come up with a catastrophic failure. And even less surprised it was you 5speed!
Not a ford...my 86 IROC. My son refuses to go on road trips in it now with me. Twice he did, twice it let us down. lol
It happens more often than you think. Across all brands.desertrefugee wrote:Yikes! Somehow I knew that one of our fun members would come up with a catastrophic failure. And even less surprised it was you 5speed!
- Rusty Probie
Had a mate who had a slow coolant leak on 75 Gl1000, it was coming down the radiator unseen from the radiator cap which after replacement stopped.
If you stay close to home, it may hang in there. I checked a non leaker on my 78 that was parked for 20 years. It was really wobbly so I replaced it just because I don't mind spending on it and wanted the peace of mind for a thousand mile each way ride at 80 mph.
- 7 Replies
- 804 Views
Last post by gregforesi
- 2 Replies
- 391 Views
Last post by chewy999
- 11 Replies
- 765 Views
Last post by rooster4321
- 12 Replies
- 845 Views
Last post by CYBORG
- 17 Replies
- 1154 Views
Last post by Don R
