I guess I left myself wide open for that one. No beads, proper stick on or spoke type weights are used, with a yellow paint dot next to the weight to alert me to a lost one.CYBORG wrote:How do YOU determine how many beads to use?LuckyEddie wrote:Harbor freight #98488. Works fine for me for many years now.
Balancing Act
- LuckyEddie
Re: Balancing Act
LuckyEddie
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
1976 GL1000
1980 XS1100LG
1982 XV750J
1981 XV920RH
Re: Balancing Act
Sorry. Thought you were talking bout beadsLuckyEddie wrote:I guess I left myself wide open for that one. No beads, proper stick on or spoke type weights are used, with a yellow paint dot next to the weight to alert me to a lost one.CYBORG wrote:How do YOU determine how many beads to use?LuckyEddie wrote:Harbor freight #98488. Works fine for me for many years now.
- Dirty Dave
Re: Balancing Act
I have a problem...... I do whatever Robin says.
I hope he never says to jump off a bridge because I WOULD.....
(a small bridge)
Seriously, I will check this product out.
(a small bridge)
1978/9 GL1000
1997 Honda Valkyrie
2018 Kawasaki Z900 RS
1997 Honda Valkyrie
Re: Balancing Act
it's kinda like a sealed battery.Dirty Dave wrote:I have a problem...... I do whatever Robin says.
(a small bridge)
install..........and never look back, or worry about it
Re: Balancing Act
Should always listen to Robin...…. he knows stuff
Re: Balancing Act
i looked up a forum on another site about 'balancing' using Dynabeads or an equivalent, and some bloke had used 4oz Air Soft pellets... and i thought i was cheap
Re: Balancing Act
SOME PEOPLE!!!!!!! but he is on another site
Re: Balancing Act
That's just crazy talk there.Dirty Dave wrote:I have a problem...... I do whatever Robin says.
(a small bridge)
- hoganJr
Re: Balancing Act
The guy who always sold and mounted the inexpensive tires I used to buy didn't think the rear needed to be balanced at all and only balanced the front if you asked him to. The guy I bought my "premium" tires from sent the front tire back to the distributor for replacement because he felt like it required too much weight to balance.
HoganJr
HoganJr
1991 GL1500
Re: Balancing Act
Tale of two dealers. Only one deserves to still be in business. In my opinionhoganJr wrote:The guy who always sold and mounted the inexpensive tires I used to buy didn't think the rear needed to be balanced at all and only balanced the front if you asked him to. The guy I bought my "premium" tires from sent the front tire back to the distributor for replacement because he felt like it required too much weight to balance.
HoganJr
Re: Balancing Act
I agree.CYBORG wrote:Tale of two dealers. Only one deserves to still be in business. In my opinionhoganJr wrote:The guy who always sold and mounted the inexpensive tires I used to buy didn't think the rear needed to be balanced at all and only balanced the front if you asked him to. The guy I bought my "premium" tires from sent the front tire back to the distributor for replacement because he felt like it required too much weight to balance.
HoganJr
Re: Balancing Act
it was the best of times.... it was the worst of times....
Re: Balancing Act
I purchased a few different sized cones from no-mar (to fit different bike wheels), some bar stock from the local hardware store (1/2" I think) and a couple of bearings off eBay with the proper inside diameter. I believe my total investment, not including a couple of jack stands I already had, was about $15 -$20rcmatt007 wrote:what I meant (beside the beads) was where did people get the tool to balance their tires
I built this about 15 years ago and still use it today.
Re: Balancing Act
I just use the little flat bar stock saved from other rims and some fresh 2 sided tape. Couple jack stands and smooth running bearings and play with it.
- 05c50
Re: Balancing Act
OK, we've got two pages of the necessity/benefit of balancing motorcycle tires, now let's move onto the necessity/balancing of Dynamic balancing compared to Static balancing. And then onto Road Force balancing and match mounting.
......Paul
......Paul
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
