Solid clutch
- transitman
Solid clutch
Hi.
Carefully dismantled and rebuilt the clutch. Everything looked ok. Fitted the cable and tried it but got no movement at all. Pulled it apart and it's now on the bench but can't see anything wrong.
Can anyone advise on what could be wrong?
"Say not the struggle naught availeth." A H Clough.
'78 GL1000 Trike
1st bike: '58 150cc Ambassador 2 stroke. learned how to chuck it down the road
'31 BSA 500 single long stroke Sloper, dug out of a wall in Sussex, never went that well...
'49 Sunbeam S8, built from bits in '67, used daily, sold to a US biker in '84, still miss it
3 BSA Bantams, now a daughter has one
'78 Honda 500T
'78 GL1000 Trike
'78 Honda 500T
- Dirty Dave
Re: Solid clutch
Never having rebuilt a clutch myself the only thing that comes to mind is the soaking of the plates in oil before assembly.
Way off?
Way off?
1978/9 GL1000
1997 Honda Valkyrie
2018 Kawasaki Z900 RS
1997 Honda Valkyrie
- flyin900
Re: Solid clutch
The small plate with the 3 ball bearings that is activated by the push rod may not be assembled correctly. If not it will present as a solid immovable clutch.
Current Bikes:
Re: Solid clutch
Describe "rebuilt".
Put in all new plates?
Did you readjusted the preload screw?
- Sagebrush
Re: Solid clutch
I assembled the rear cover on an 1100 with the cam that pushes against the push rod in the wrong position and it felt solid. I suspect your problem is right there. I had to remove the cover and correct it.The small plate with the 3 ball bearings that is activated by the push rod may not be assembled correctly. If not it will present as a solid immovable clutch.
- transitman
Re: Solid clutch
Thanks for the responses.
This is the 7 year building a trike story detailed in tech discussions. All new plates and a new lifter and pressure plate and new cable. Followed Old Fogeys guidelines and removed plate B replacing with 2 standard plates. Followed the workshop manual exactly in rebuilding. Freed off and lubed the little cam plate and adjuster and set it as per. Refitted and adjusted the cable but there is no give at all in the clutch assembly when pulling the lever. Could see the slack taken up as I pulled the lever as there is no fuel tank in the way.
Pulled it all apart and the whole assembly is laid out on the bench. Had a really close look at everything but can't see anything amiss.
'78 GL1000 Trike
'78 Honda 500T
'78 GL1000 Trike
'78 Honda 500T
- flyin900
Re: Solid clutch
There are two ways that little cam plate with the ball bearings will assemble. One way works and one way it is solid and immovable. I am not familiar with the two replacement plates used for the damper plate as I have never tried that procedure.
Assemble the clutch rear cover plate and operate the lever that the cable attaches to and see how the little plate rotates. It should raise the assembly outward when you pull on the lever in the correct direction.
Current Bikes:
- transitman
Re: Solid clutch
Ok, thanks I will try that first thing tomorrow
'78 GL1000 Trike
'78 Honda 500T
'78 GL1000 Trike
'78 Honda 500T
- transitman
Re: Solid clutch
Yes. It moves nicely, smooth and greased
'78 GL1000 Trike
'78 Honda 500T
'78 GL1000 Trike
'78 Honda 500T
- RIP: cookie
Re: Solid clutch
Good news .... love it when the site members fix things !!
