How do you remove a rounded over brake bleeder valve?
- dbtroudy
This afternoon I started to rebuild the front brakes on my '76 Yellow. I discovered that the brake bleeder valve on the left side brake caliper was rounded over and an 8 mm wrench or socket would not grab the valve to remove it from the caliper body. I tried heat, PB Blaster and taping the valve - no luck in budging it. Any suggestions would be appreciated.
Don
Don
- IMG_0187.JPG (151.64 KiB) Viewed 255 times
- IMG_0188.JPG (123.34 KiB) Viewed 255 times
DBTroudy
Fullerton, CA
'03 GW GL1800 Yellow
'76 GW GL1000 LTD #859
'75 CB200T
Fullerton, CA
'75 CB200T
- tomk1960
Re: How do you remove a rounded over brake bleeder valve?
Since the bleeder is ruined, I'd heat it up good, then grab it well with vice grips and try to break it loose. Try moving it a little bit, then heat some more, move a bit more, etc.
1986 VFR750F Interceptor
1978 Honda GL1000
1978 Honda GL1000
When it's hot hit is with PB blaster. Try this a few times and then try the vice grips. cycling it hot-cold with PB blaster will help the stuff get down into the threads.
-P.
-P.
- dbtroudy
I did take a propane torch to it and got it pretty hot. I then used both a large and small set of vice grips without success. Tomorrow I’ll pop out the piston and remove the rubber seal and give it another try.
DBTroudy
Fullerton, CA
'75 CB200T
Fullerton, CA
'75 CB200T
- wog
Sounds silly, but drill a hole in an icecube less than the size as the bleeder, heat the caliper area nice and toasty, place the ice on the bleeder to cool (shrink) it, and remove with pliers.
- JamesPal
Good idea getting the piston out first.
Try filing some flats on the bleeder. Get them as close to the base as possible. The flats should give your vice grips some purchase on the caliper body. The body is aluminum alloy and the bleed valve is steel. Heat will cause the aluminum to expand more than the steel. Hot and cold cycles will break the corrosion.
'85 GL1200I
'81 GL1100 STD
'72 CB450
'85 GL1200I
'81 GL1100 STD
'72 CB450
- calif wingnut
I snapped off one trying to remove, so I drilled it out with the next size smaller bit and picked the threads out. You could also try heating it and using candle wax.
Heat the caliper up really well around the bleeder screw then hit the bleeder screw with pb blaster.dbtroudy wrote:I did take a propane torch to it and got it pretty hot. I then used both a large and small set of vice grips without success. Tomorrow I’ll pop out the piston and remove the rubber seal and give it another try.
Candle wax as lube or ??calif wingnut wrote:I snapped off one trying to remove, so I drilled it out with the next size smaller bit and picked the threads out. You could also try heating it and using candle wax.
Please explain.
78 GL1000 Original Owner 131k
- dbtroudy
I took my Dremell grinder and squared up the sides of the bleeder so I could put a 7 mm wrench on it. I also removed the piston and rubber seal and filled the bleeder hole with Liquid Wrench. I’m going to let it sit for a while and then heat up the caliper with my propane torch and see how it goes from here!
- D5E73F5F-BC17-4937-86D8-A70F65C8E7FC.jpeg (279.21 KiB) Viewed 181 times
- F0C3250B-5371-45E1-A684-77ACC51B191A.jpeg (239.02 KiB) Viewed 181 times
DBTroudy
Fullerton, CA
'75 CB200T
Fullerton, CA
'75 CB200T
the wax melts and gets down in the threads and free's it up.SnoBrdr wrote:Candle wax as lube or ??calif wingnut wrote:I snapped off one trying to remove, so I drilled it out with the next size smaller bit and picked the threads out. You could also try heating it and using candle wax.
Please explain.
- dbtroudy
Using the suggested methods of grinding flats on the sides of the bleeder, heating the caliper with a propane torch and shocking the bleeder valve with ice, I was able to break the bleeder loose and remove it from the caliper.
Thanks everyone for your help!!
Don
Don
- 5A51BA4A-1F02-4313-B427-3A31608C543A.jpeg (353.88 KiB) Viewed 130 times
DBTroudy
Fullerton, CA
'75 CB200T
Fullerton, CA
'75 CB200T
wog wrote:Sounds silly, but drill a hole in an icecube less than the size as the bleeder, heat the caliper area nice and toasty, place the ice on the bleeder to cool (shrink) it, and remove with pliers.
Now I got a picture in my head of you in your shop, drilling a ice cube....
but, if you are suggesting it, I am sure it works, but the picture is still funny
- dbtroudy
Believe me, it worked. A hole in an ice cube and all!!
DBTroudy
Fullerton, CA
'75 CB200T
Fullerton, CA
'75 CB200T
- wog
Yeah, but I do it with the CNC mill, got to be extremely precise when machining frozen H2O!
Dbtroudy, glad it worked for you.
- 333 Views
Last post by pidjones
- 173 Views
Last post by Oldtech
- 15 Replies
- 914 Views
Last post by redglbx
- 16 Replies
- 996 Views
Last post by Sidecar Bob
