Do you mill an undersized hole to allow for melting ??
Gord(been known to put ice in my beer)Jones
How do you remove a rounded over brake bleeder valve?
- RIP: cookie
Re: How do you remove a rounded over brake bleeder valve?
Is it normal for the bleeder screw to stick that far into the caliper? Looks like it might interfere with the piston travel.
- dbtroudy
The bleeder screw does not enter the piston camber. If you look at the picture I posted of the caliper internals with the piston removed, the smaller of the two holes is the bleeder hole. The larger hole is where the brake line and banjo connect up to the caliper.
Don
Don
DBTroudy
Fullerton, CA
'03 GW GL1800 Yellow
'76 GW GL1000 LTD #859
'75 CB200T
Fullerton, CA
'75 CB200T
this one? It looks like the bottom of the bleeder screw sticking into the bore for the piston.dbtroudy wrote:The bleeder screw does not enter the piston camber. If you look at the picture I posted of the caliper internals with the piston removed, the smaller of the two holes is the bleeder hole. The larger hole is where the brake line and banjo connect up to the caliper.
Don
- F0C3250B-5371-45E1-A684-77ACC51B191A.jpeg (129.12 KiB) Viewed 100 times
- dbtroudy
It’s the brake line banjo bolt that is tapped into the caliper housing at 10 o’clock in the picture. The bleeder valve is the hole at 2 o’clock.
DBTroudy
Fullerton, CA
'75 CB200T
Fullerton, CA
'75 CB200T
I'm blaming it on an optical illusion..now that I look at it again I can see it is a threaded hole and not the end of the bleeder screw.dbtroudy wrote:It’s the brake line banjo bolt that is tapped into the caliper housing at 10 o’clock in the picture. The bleeder valve is the hole at 2 o’clock.
that is my story and I'm sticking to it.
- dbtroudy
5Speed,
I understand, no offense taken.
Don
Don
DBTroudy
Fullerton, CA
'75 CB200T
Fullerton, CA
'75 CB200T
- 333 Views
Last post by pidjones
- 173 Views
Last post by Oldtech
- 15 Replies
- 914 Views
Last post by redglbx
- 16 Replies
- 996 Views
Last post by Sidecar Bob
