peat is meant for the fire...rcmatt007 wrote:talisker, oban or laphroaig
rear tyre
Re: rear tyre
Re: rear tyre
and for the smoke for the barley
Re: rear tyre
I will add it to the list. I was a Crown guy until a friend turned me onto the 40 Creek. I'm not a frequent drinker so it may go bad.ifm61 wrote:
booze is a topic i actually do know somethin' about... try the Bushmills, as long as you remember once that cap twists off, it too has a shelf life...
Re: rear tyre
wow, I'm hanging with the hoity-toity crowd.
if I'm not drinking my own, homemade mead, I'm drinking cheap vodka.
this is what I rode to Deadwood last summer, as some of you saw.
did anybody check the date code?
H2G2=42
H2G2=42
Re: rear tyre
[quote="heraldhamster"]wow, I'm hanging with the hoity-toity crowd.
i hear that brother! unkle boris is a good buddy of mine also; the Bushmills is for when the pope visits. nice picture of Telly Savalas b.t.w.
Re: rear tyre
I have a cyser fermenting as I type :D
Re: rear tyre
NICE!stretch160 wrote:I have a cyser fermenting as I type :D
H2G2=42
H2G2=42
- Sagebrush
Re: rear tyre
heraldhamster wrote:wow, I'm hanging with the hoity-toity crowd.
I've been wondering how that tire did on the way home without being balanced? Any issues with it?
Re: rear tyre
update and a tangent... front wheel: new tyre, new bearings, back on the bike. rear wheel: new tyre and bearings purchased, can't get the bloody rear wheel out the bike...
The main culprit appears to be the caliper bracket which appears held on to the swing arm by that one arrowed nut (size anyone?)
I've the caliper split from the easier accessed r/h side, I've air out of the old 130 (replacing with 120) tyre, the axle removed, the rear drive out of the driveshaft but obviously still attached to the wheel, but i still don't see how removing that 1 nut will allow the caliper bracket to come away from the swing arm and free up enough space for me to pull the wheel out...
I need the wisdom!
I need the wisdom!
Re: rear tyre
When I've removed the rear on my 78, I removed the bracket stay bolt (17mm or 19mm), the axle nut, loosened the rotor nuts (shouldn't be necessary with a 17" wheel), removed the axle spacer on the left side, and slid the wheel to the left clear of the final drive unit.
To keep the subjective opinions going: the best vintage bike tires are Spitfires (Metzeler pilots for sport bikes), the best engine oil is Castrol, and I don't drink but I do shoot so 10mm trumps 9mm and 45 cal. Have a good evening!
Re: rear tyre
It has been a long time since I had a 1000 so I can't remember how I removed the rear wheel except that one time the spacer rusted onto the axle and I had to cut them both to get it apart to fix a flat
I had a Spitfire once but I didn't like it much. I have a Shinko 240 on the rear of my 'Wing and plan to replace it with the same. Its not a tire I would choose for a solo bike but mine doesn't lean much anymore. I've been using Castrol 4-stroke Motorcycle oil for a few years and it seems OK. I am in the process of renovating a space in my rec room so I can make my own beer & wine so I can have something decent without paying through the nose. I occasionally help my friend fire his cannon (8" bore, 45' long). It trumps anything you can carry
Re: rear tyre
I've used Kendas, IRCs, Avon's, Pirellis, etc and they all have their pros and cons. I'm pretty sure any quality oil does pretty well these days. Cannons are fun. A lot of work, but worth it. Most folks never experience that kind of concussive blast.
- tlbranth
Re: rear tyre
I think some of this tire stuff is dogma that someone read somewhere and repeated and someone else read it and passed it on 'til it became gospel. True of lots of things ..... like stators will always fail etc.
After a while you'll get to know who actually knows something and who only thinks they do......'cos they read it on a forum.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Re: rear tyre
If you have a 16 inch wheel on the back the caliper is almost impossible to remove. Easiest thing to do is to unbolt the brake disc and tip it to the side to remove the caliper. Only takes a few minutes. be sure to replace the disc nuts or use a lock tight as they are one time use so they retain the torque.
Re: rear tyre
I've a 17" on the rear, thankfully, but it is an option worth considering. The bracket stay bolt would appear to be a p.o. Frankenspecial. It may well be the 17 or 19mm ID as mentioned in the thread, but I've tried the biggest socket currently available to me (21mm) and its still shy. When I do find something that'll fit it, is my best option to put the axle back in so i can get some wrenching torque on the bugger without hitting myself in the face with the swingarm?
- 28 Replies
- 4046 Views
Last post by JonathonCranny
- 24 Replies
- 821 Views
Last post by Sidecar Bob
- 28 Replies
- 4371 Views
Last post by rcmatt007
- 6 Replies
- 2088 Views
