gl12000 into a 1000 frame 76 carbs
Re: gl12000 into a 1000 frame 76 carbs
If you don’t plug them you will have an open hole from the exhaust port of the head to near the carbs, a potential boom-boom. I’ll take some pics if I can.
Ok, I get that. I didn't know if you had gotten the engine or whole bike for $400. I was just curious if maybe the 1000 frame was better than the 1200 frame for some reason. I'm building my 75 1000 now and plan on working on the 1200 nextpierce wrote:I have a 1000 frame available, no 1200 frame.brewer013 wrote:Kinda off topic... what is the reason you are wanting to put a 1200 in a 1000 frame other than the obvious? Why not build the 1200 to your liking? Seems like a popular swap
1975 Honda Goldwing GL1000 (café project, started Oct 2018)
1978 Honda CB400T Hawk II (son's project)
1980 Honda CB750C Café
1986 Honda Goldwing GL1200 stock dresser
If you crawl underneath yours or tip it up, with a flashlight you’ll see it.
I found this pic in my folders
You will definitely need to plug the holes but it will run fine without the tubes. I have removed them from a Valkyrie and a 1200.pierce wrote:I am running 76 carbs, so would I need to do anything to those holes (really)?
ericheath wrote:Part of the “afterburner” for the turbinator so the flux capacitor doesn’t get too hot.
There are o-ringed tubes which fit there.
To use it you need the 1200 carbs and intakes. Guys who disable it plug the hole with JB and whatever. I bought four freeze plugs close to size and used JB to seal. The hole leads down to a port in the exhaust. Each hole goes up to a collector under the base of the plenum. I never looked into what it actually does. Probably adds air to pass emissions testing??? Another option is using the tubes/hoses and plugging the plenum end.
- pierce
- My Album: pierce
Ok, I'll look for some plugs and jb weld them in.
For those that have used the black box, where did you mount it?
Got the shaft in place, so about ready to get the engine in, and black box wired up.
Now I realize that reason the shaft needs to be swapped out. There is no groove on the 1200 for the snap ring.
1976 GL1000
1978 Gl1000
1978 Gl1000
Being that you have completely done a 1000, it might be worth it to look at the starter chain cogs, if nothing else than to clean sand relube.
Others have tried the 1000 shaft on the 1200 output shaft and it did come off. You’re close, but far from riding season.
You have to plug them if you don't use the 1200 intake manifolds. If not there will be a massive exhaust leak. That is part of the emissions system.pierce wrote:I am running 76 carbs, so would I need to do anything to those holes (really)?
I fabricated brackets to mount 1200 coils where the originals were, and a bracket to mount the ignition box to them. Be aware, it was a lot of screwing around. I wanted to use the 1200 airbox, and it's really, really tight.
- 20180226_121927.jpg (81.7 KiB) Viewed 129 times
- 20180226_123232.jpg (65.98 KiB) Viewed 129 times
- 20180226_123658.jpg (140.67 KiB) Viewed 129 times
- 20180226_124843.jpg (130.1 KiB) Viewed 129 times
- 20180226_123707.jpg (133.55 KiB) Viewed 129 times
If I recall correctly the air box almost hits the heat shield on the lower right side. I carved out the center section of the shield leaving the two braces. It makes for easier installation.
I haven’t figured out a way for my V65 carbs to be enriched when decelerating. So I have a little farting going on when I slow down. For me, it’s appropriate.
- pierce
- My Album: pierce
That looks pretty amazing. I looked at the space i have with the dyna coils, and i just don't think I'll be able to make that work.Shadowjack wrote:I fabricated brackets to mount 1200 coils where the originals were, and a bracket to mount the ignition box to them. Be aware, it was a lot of screwing around. I wanted to use the 1200 airbox, and it's really, really tight.
I'm leaning towards the right side shelter, and bolting it in place. I would like to find a location closer to the coils and carbs,but there's little space.
How did you connect the vacuum house to the carbs? That would be my next dilemma,as the hose would have to be longer than i would like if it's in the shelter.
Other option would be above the airbox, but then i would lose my tool tray.
1976 GL1000
1978 Gl1000
1978 Gl1000
- pierce
- My Album: pierce
I removed my heat shield.ericheath wrote:If I recall correctly the air box almost hits the heat shield on the lower right side. I carved out the center section of the shield leaving the two braces. It makes for easier installation.
1976 GL1000
1978 Gl1000
1978 Gl1000
- sgwilly
You should consider putting a neon coil in there. The towers are off the side and wouldn't interfere with your airbox. Also kicks out a pretty good spark for cheap. Lot's of threads on that - here's mine where I put it in an '83.
Neon coil mounted in 83 1100
Steve
'09 Yamaha FJR1300AE
'99 Valkyrie Tourer
'89 Isuzu Trooper 3.4L
'83 GL1100 MonkeyWing (on IR)
'75 GL1000 (in the queue)
'64 MGB
IBA #58082
SGWilly Gallery
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
Just a thought, I wonder if the impulse from the coils might interfere or even damage the control box. When I installed the M box wiring system they cautioned to mount the control box at least a foot away from the coils.
- sgwilly
I was thinking the same thing when I saw that.Easter wrote:Just a thought, I wonder if the impulse from the coils might interfere or even damage the control box. When I installed the M box wiring system they cautioned to mount the control box at least a foot away from the coils.
Steve
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
- 18 Replies
- 555 Views
Last post by ericheath
