Dyna S issues
Re: Dyna S issues
could be something silly. In my case it was heat related. Both modules test good when the bike ws cold. Ran good till everything warmed up. Then one module would fail. System was several years old, ..but still. Let it cool off,...all was good. Several miles later would fail again,...until it cooled off. Always tested good in the shop,...failed on the road.
replacing the module solved the problem. A year or so later installed a C5, and never went back. Easier to tune, and more tuning options. MUCH better then a dyna...…..in my opinion
- scootsx2
Re: Dyna S issues
I had a similar failure scenario with the "brand-x" ignition that was on my bike when I bought it 9 years ago. It finally failed hard, fortunately close to home, so it was easy to diagnose. Replaced it with a Dyna.CYBORG wrote:could something silly. In my case it was heat related. Both modules test good when the bike ws cold. Ran good till everything warmed up. Then one module would fail. System was several years old, ..but still. Let it cool off,...all was good. Several miles later would fail again,...until it cooled off. Always tested good in the shop,...failed on the road.
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
Re: Dyna S issues
Plug caps are relatively cheap. Just sayin'
- Sandy
Re: Dyna S issues
Have just had to replace the Dyna S system on my 76.
New 2015, started to cut in and out while riding.
I did make an inquiry through the Dyna Tech website but got no reply.
I have used Dyna S on the 3 wings in the collection and can only recall one other failure years ago.
Just wish there was some way to diagnose which p/u was the culprit.
Re: Dyna S issues
Utilize this document, Sandy.Sandy wrote:Have just had to replace the Dyna S system on my 76.
With a multi-meter You can perform these static tests with the engine at operating temperatures, too.
https://www.mpsracing.com/instructions/ ... esting.pdf
Cliff (74yrs )
- todd54219
Re: Dyna S issues
Had similar issue earlier this year. It took about 25+ miles to get it to act up but it would cut out for a while then all was good. It would not act up when I had it in the garage. It actually started a year ago. I thought I was fouling plugs as I was riding 2 up and not using as much wrist. I was able to catch it acting up about 2 blocks from my house and pulled a spark plug wire or 2 and was able to determine it was an ignition issue. I finally replaced the DYNA ignition and all is good in the hood. The unit was about 10 years old so it was and still is worth the cost. I could not justify the C5 system but I wish I could.could be something silly. In my case it was heat related. Both modules test good when the bike was cold. Ran good till everything warmed up. Then one module would fail. System was several years old, ..but still. Let it cool off,...all was good. Several miles later would fail again,...until it cooled off. Always tested good in the shop,...failed on the road.
Todd
1976 Yellow GL1000
1976 Yellow GL1000
Re: Dyna S issues
I understand the money issue. But when you consider that the C5 system comes with a special coil, spark plug wires, and an optical ignition that is super easy to setup. And electronic advance. If the cost is looked at considering what you get, it starts looking better. It IS the 21st century ignition system. Try it,...…..you will like it
Re: Dyna S issues
Don't put it off too long because the Dyna S warranty is only good for 1 year.
Here's how to test it http://www.dynaonline.com/skins/downloa ... naSTSG.pdf
Re: Dyna S issues
CYBORG wrote:I understand the money issue. But when you consider that the C5 system comes with a special coil, spark plug wires, and an optical ignition that is super easy to setup. And electronic advance. If the cost is looked at considering what you get, it starts looking better. It IS the 21st century ignition system. Try it,...…..you will like it
Cyborg, not trying to hijack the thread but what coils did you go with? VS4 or the MV version? For a 76 GL1000
Re: Dyna S issues
I used the coils that came with the C5 kit. One coil pack, four sparkplug leads
Re: Dyna S issues
Who sells the C5 system? I was planning on installing a Dyna but the C5 sounds good too.
John
1976 Honda GL1000 LTD
1999 Honda Valkyrie Tourer
2001 Kawasaki ZRX 1200R
Re: Dyna S issues
Paul Crowe sells them. C5 ignitions.com
Re: Dyna S issues
Ok so what does it mean when I have 12v power source to the dyna but when I try to static time it with a test light the test light doesn't light up to check the timing. What am I missing
Re: Dyna S issues
Off‐ Run- Off handle bar switch is set to Run
https://ngwclub.com/forum/viewtopic.php?t=5720
IMPORTANT!! Just noted this ^^^^ tutorial doesn't indicate the OFF RUN OFF switch has to be selected to the RUN position.
text located under the 6th photograph says only, "...turn ON ignition ." I reckon that could be interpreted as the keyswitch alone.
Now you know. "kill switch" must be selected to RUN, as well.
updated links to Dynatek GL1000 Dyna S documents; no longer found on the Dynatek website:
https://www.mpsracing.com/instructions/ ... /DS1-3.pdf
Cliff (74yrs )
Re: Dyna S issues
Yea I have rotated the bike several rotations on both off an run just to make sure I didn't have wires backwards. How do I check to see if the dyna s is good
