Just about discouraged
Well I said I would report back. 1980 GL1100I 1 front and back caliper thourgholy cleans. New rubber new 43mm pistons are still leaking! I don’t no weather to just ignore the problem or take them apart again. Is there nothing that can be put I groove behind square o ring to help seal it up? I’m really at my wits end!
- scootsx2
Re: Just about discouraged
You shouldn't put anything in the groove except the seal. Did you lubricate the seal with brake fluid prior to assembly? Perhaps the seal was torn or twisted during assembly. Is the piston wall smooth (no corrosion, pits or scratches)?
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
Yes new piston, new o-ring and dust seal, lubed in brake fluid o-ring and piston. Was carful to get straight and slide in gently. Clean groove out carefully w/a pick and brake cleaner. This is like 3rd or 4th assembly. Was in leaky front caliper. Should have stayed w/ original post I suppose.
You mentioned a leaking fork seal in the other thread. Are you absolutely sure it is brake fluid that is leaking?
BTW: I found that if I applied silicone grease (recommended for lubricating brake parts for assembly) into the grooves in the bores of the caliper on my winter machine before I installed the rubber rings there was less corrosion in the grooves the next time I had the caliper apart so I have started doing that on the GoldWing too. It wouldn't stop a leak but it is something other than the seal that can be put into the grooves.
- scootsx2
I have been using Brakemasters seal & piston kits when I rebuild calipers. They include a container of pink silicone grease in each kit.Sidecar Bob wrote:BTW: I found that if I applied silicone grease (recommended for lubricating brake parts for assembly) into the grooves in the bores of the caliper...
https://brake-masters.com/
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
- tlbranth
If your piston is new, rubber ring is new and it leaks, something's bad in the groove. I flinched when you said you used a 'pick' to clean the groove. I hope you meant a toothpick. some Brakleen and a wood toothpick or two are good for getting the crud out of the corners. Brakleen and cotton swabs are good for finishing up. NAPA sells a brake assembly fluid that's good for lubing it all up for assembly.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- flyin900
Plus#1 on this question. If you damaged the grooved seal area by using a metal scraping tool then that could be your issue. If the groove is nice and clean and undamaged then with all the new parts there should be no issues with leaks.tlbranth wrote:If your piston is new, rubber ring is new and it leaks, something's bad in the groove. I flinched when you said you used a 'pick' to clean the groove. I hope you meant a toothpick. some Brakleen and a wood toothpick or two are good for getting the crud out of the corners. Brakleen and cotton swabs are good for finishing up. NAPA sells a brake assembly fluid that's good for lubing it all up for assembly.
Pictures of the bare calipers if you decide to take them apart again with the seals removed would give a better idea of the surface areas and what your dealing with presently.
Current Bikes:
I use a pick for the groove every time, just have to watch and be sure that you aren't damaging the metal. I use a special one with a dulled tip to scrape the corrosion that builds up behind the seal. That said, something is wrong if it's leaking. Is it possible that you damaged the seal groove or missed a spot in the groove that now makes the seal sit out of round? Was the piston pitted? Pitting creates sharp edges that can cut seals. If none of those are going on you may check the really unusual stuff and measure the piston and bore to determine roundness. Some photos may help. Good luck with it.
I’m sure no damage to groove. Used a small curved, blunt tool my wife uses in wood working. Calipers are not pitted. The groove seems wide for seal. Up and down wide.
Parts are oem equivalents from gallery power sports. Off eBay.
On two different occasions I have received piston seals that on close examination (on disassembly after leaking) I discovered a small molding discrepancy that I first thought was my fault in the original assembly, but on closer examination proved to be a factory error. Hopefully all of these are out of circulation by now (within the last year) but worth checking carefully before installing. Since then I have been sticking with OEM only.
This may be obvious, but there's a fluid seal and a dust seal. Not getting the grooves mixed up, I hope?
Well I always said my wife can do it better. I took rear caliper off last night(that’s the one that’s been leaking), and she said let me put it back together, and guess what just got home and cked and it’s dry as a bone!
you're never going to live that down.Edmaddox wrote:Well I always said my wife can do it better. I took rear caliper off last night(that’s the one that’s been leaking), and she said let me put it back together, and guess what just got home and cked and it’s dry as a bone!
Yeah, but the next time you need a caliper rebuilt you can call on her "expertise" in that area
