So my issue is not with the turn signal. It's actually the tail lamp causing the problem.uyh
So I put the tail end of the bike back together and when I connect these together, the 5A Tail fuse blows.
Also, as you can see in the pic, the wire colors are opposite when connected. Do they not belong together?
Edit* Tail Lamp Problem
- Brass Member
Last edited by Willwll313wll on Tue Aug 14, 2018 8:43 pm, edited 4 times in total.
- Brass Member
Re: Turn Signal Problem
Here's a couple pics of my bike as well. I picked it up lmk ast year for around $600 or so. Wasn't running, among other things but it's doing fine now!
Can't wait to get it looking the way i want.
- 20180813_192424.jpg (74.67 KiB) Viewed 158 times
- 20180813_192438.jpg (68 KiB) Viewed 158 times
- 20180514_190007.jpg (94.44 KiB) Viewed 158 times
- 20180603_171610.jpg (109.6 KiB) Viewed 158 times
- Brass Member
Though I still don't know how the Signal Relay connects in relation to those three wires but I'm guessing my fuse blowing is because the positive turn signal wire is shorting somewhere. I'm going to follow the wire around later this afternoon when I get off and see what I can find.
-Virgin Electrician
-Virgin Electrician
- salukispeed
Having a schematic is helpful . I believe the brown is tail filament the Green/yellow is brake filament and the Green is ground for the socket and often the fender for a ground required for the turn signals ( lt blue and orange ) any other connection to the Green may be a shorted condition. Double checking just the tail light light assembly with a battery charger can expose a shorted wire harness or socket and re checking with the ground at the fender too along with the Green Easy to pinch a wire and not know it.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
- Brass Member
Re: Edit* Tail Lamp Problem
Updated findings, see first post. I'm guessing that was my issue, leaving it unplugged solves my problem and everything works as it should... learning curve guys.
In your first pic, that is not a stock connector, so any wiring advice given based on original colors is not going to help much. I would suggest you go backwards under the seat until you find the original wiring harness so you can sort out what colors have been changed. There's a good (and free) wiring diagram available in ShopTalk specifically for each year of the 1000's. That and a test light or multimeter should get you on your way...
- Brass Member
Thanks. I've solved the issue.Track T 2411 wrote:In your first pic, that is not a stock connector, so any wiring advice given based on original colors is not going to help much. I would suggest you go backwards under the seat until you find the original wiring harness so you can sort out what colors have been changed. There's a good (and free) wiring diagram available in ShopTalk specifically for each year of the 1000's. That and a test light or multimeter should get you on your way...
I'd be looking into where those connectors are wired to and would probably remove them before they cause more problems.
BTW: There's a direct link to the schematics in my signature. Even if you don't need it for this its a good idea to have it for the next time you are working on the wiring.
