Starter or Engine Damage?
- Solina Dave
I have a '78 GL1000, and I'm not too well versed in the operation of an over-running clutch. I do however have a question that I believe is related to that design feature.
I want to be able to flash my headlight at oncoming traffic, while the bike is in motion, and also when the bike is stopped. With the bike in motion the clutch is obviously engaged, and the clutch lever is "out". The clutch lever switch is "open". If I depress the starter switch, the starter shouldn't spin. But will the headlight still go out?
And also, if I were stopped at a stop sign for instance, and wished to flash my headlight at another vehicle across the intersection, would that work without problem? The engine is sill obviously running, but this time the clutch lever is "in", and the clutch lever switch is closed. Would the starter spin, and try to engage, and potentially cause damage? I don't know.
I also don't know if this is relevant or not. But with the bike in motion, rpm would be high. and at a stop, rpm would be comparatively low.
I accidentally depressed my starter button a while back, while the bike was in motion. I don't think that the starter tried to spin, but I couldn't hear all that well with engine, road, and wind noise. I've never tried it with the bike stopped.
Any help would be welcome. I remember my old car making a hell of a racket when I'd accidentally turn the key in the ignition with the engine already running. Sound familiar?
..................Dave
"ASSUME NOTHING"
1st motorcycle-1977 Honda CB550F Super Sport
2nd motorcycle-1978 GL1000
"Not riding a motorcycle is wrong"
- RB
Re: Starter or Engine Damage?
easier to install a switch in the headlight circuit
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
The starter has its own clutch. If you push the start button with the engine running. the starter will activate, but the running engine will over ride the starter clutch. No damage to anything. Also, as part of that circuit, the headlight will go out as long as the button is in
- RIP: cookie
Yes .... the starter button will flash your headlight ....
- Solina Dave
Thank you gentlemen. That's exactly what I needed to know. And thanks for the explanation about the running engine overriding the starter clutch Cyborg. That's kind of what I'd suspected, based on what I'd been reading about the starter clutch operation. But I wasn't sure. So thanks again.
.............Dave
.............Dave
"ASSUME NOTHING"
Your welcome...…….. anytimeSolina Dave wrote:Thank you gentlemen. That's exactly what I needed to know. And thanks for the explanation about the running engine overriding the starter clutch Cyborg. That's kind of what I'd suspected, based on what I'd been reading about the starter clutch operation. But I wasn't sure. So thanks again.
.............Dave
That is actually what we tell people to do when their starter clutch is acting up. Hit the starter button while it is running. This is done in the hope it gets a little oil on the rollers to help lubricate them more and also to loosen them up.
- Solina Dave
That's good to know. Thanks Robin. I'll keep that in mind, possibly for some time in the future.robin1731 wrote:That is actually what we tell people to do when their starter clutch is acting up. Hit the starter button while it is running. This is done in the hope it gets a little oil on the rollers to help lubricate them more and also to loosen them up.
........Dave
"ASSUME NOTHING"
- Earl43P
I do that frequently on all three of my Hondas to warn and signal others. I try not to do it with the clutch held in making the starter run, but as said, it won't hurt it. I did it on my 82 also. Truckers appreciate it when you signal that they are clear to come over, and acknowledge back with their tail lights. I think it's a good practice. For that I use 2 longer off intervals with a short on in between. Seems to be how they signal each other clear to change lane so I mimic that, even in my pickup.RAT wrote:Yes .... the starter button will flash your headlight ....
I use quick off blinks at a 4way stop sign intersection to confirm that I know it's their turn to go (along with an exaggerated planting of both feet). Even with the clutch in, the starter doesn't engage much if any if you don't fully depress the switch. Easier to get that knack at night, for the obvious reason that you can see the light go out. My 93 is especially easy to master because it has a lever with a lot more travel, not a button.
I can also be obnoxious with it, using high beams and rapid flashing usually wakes up a left lane camper to move over as I'm gaining on them. That isn't as effective up here in NoVA as it was in rural NC.
KTM390A “Hootinanny”
04 ST1300 DDDD (Double darksided daily driver) Sold 4/2022
93 GL1500I Double darksided and SOLD 3/29/20.
99 Valkyrie IS, Fast Black Double Darksided
"Fishtailed, flipped and flung me, but wearing it well". Sold!
82 GL1100 retired DD, needs work.... Sold 3/3/17
- Old Fogey
Change your left hand switch to a UK/Euro one which has a flasher button in it.
I don’t recall reading this:
“That is actually what we tell people to do when their starter clutch is acting up. Hit the starter button while it is running. This is done in the hope it gets a little oil on the rollers to help lubricate them more and also to loosen them up.”
Good to know.
Good to know.
- 21 Replies
- 366 Views
Last post by Sidecar Bob
- 12 Replies
- 641 Views
- 12 Replies
- 345 Views
Last post by CYBORG
- 6 Replies
- 519 Views
Last post by CYBORG
