GL1000 Generator bolt cover cracked
TorontoGL
Post by TorontoGL »
Hello everyone,
Would like to know if generator bolt area breathes
I removed generator bolt cover to adjust timing and found it has a crack, question is, would it take extra air from here and influence smooth running of einge?
thanks,
Honda gave Wings
1976 GL1000 LTD X 2
1979 GL1000 Blue
1969 CB350
1966 CB450
1963 CB77
1974 CB550K
1975 CB550F
1977 CB400F
2009 Road King
and few more hondas
pjlogue
Re: GL1000 Generator bolt cover cracked
Post by pjlogue »
Unless the GL series in later years had a provision for PCV (Positive Crankcase Ventilation) no. The crank case is essentially at ambient pressure. You could probably find a replacement cover easily. I think it's a common part on the GL and 750K.
-P.
salukispeed
Post by salukispeed »
A crack in the cover should have no influence. and as was mentioned he the crank case breathes to the atmosphere and not the induction system.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
salukispeed wrote:A crack in the cover should have no influence. and as was mentioned he the crank case breathes to the atmosphere and not the induction system.
If it is stock it goes from engine, into the air box, then another tube to the breather chamber. So it does technically run through the intake system. But I also don't believe the cracked cover would have any affect.
TorontoGL
Post by TorontoGL »
Thanks everyone, I did find one and it is in mail just wanted to ensure that a leak in this cover does not impact running. Thanks,
Honda gave Wings
1976 GL1000 LTD X 2
1979 GL1000 Blue
1969 CB350
1966 CB450
1963 CB77
1974 CB550K
1975 CB550F
1977 CB400F
2009 Road King
and few more hondas
SnoBrdr
Post by SnoBrdr »
TorontoGL wrote:Thanks everyone, I did find one and it is in mail just wanted to ensure that a leak in this cover does not impact running. Thanks,
Someone broke mine off years ago.
Been running with a piece of duct tape over the hole ever since.
Color is pretty close and no running issues.
BTW, does the motor have to be out to replace that cover ?
78 GL1000 Original Owner 131k
TorontoGL
Post by TorontoGL »
No
Honda gave Wings
1976 GL1000 LTD X 2
1979 GL1000 Blue
1969 CB350
1966 CB450
1963 CB77
1974 CB550K
1975 CB550F
1977 CB400F
2009 Road King
and few more hondas
