Very slow to return to idle
My new (to me) Gl1000 is very slow to return to idle.
There's no change when adjusting the idle screw until I get to 3000 rpm. She'll then jump to 3000rpm and stay there. When take the idle screw back, she stays at 3000rpm for a while before suddenly dropping and cutting out.
I have put plenty of carb cleaner through it.
Any suggestions?
Any suggestions?
- jdvorchak
Re: Very slow to return to idle
Hello and welcome to the forum. There is no shortcut to cleaning carbs. Running plenty of carb cleaner through them usually only results in clean float bowls but does little for the idle (pilot) jets and idle circuits.
But first things first. Make sure that your valves are adjusted to factory spec. Then make sure your ignition timing is spot on using the Randakk method of "Split Timing". Make sure your mechanical advance is working freely. Then and only then can you make the determination of whether to remove and clean the carbs.
Good luck and ask plenty of questions.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- RB
Choke cable and throttle carb routing..correct not pinched or kinked someplace?? Cables clean and lubed?? next might be sticking slides,
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
Thanks, I'll check these things tomorrow. How do I know that the timing advance is working correctly, or what problems should I look out for?jdvorchak wrote:Hello and welcome to the forum. There is no shortcut to cleaning carbs. Running plenty of carb cleaner through them usually only results in clean float bowls but does little for the idle (pilot) jets and idle circuits.
All cables are free. Throttle and choke lever on the carbs are returning to their off positions as they should.RB wrote:Choke cable and throttle carb routing..correct not pinched or kinked someplace?? Cables clean and lubed?? next might be sticking slides,
- RB
Then I vote sticky slides. running some sea foam and/or some ATF with your gas fora tank or two may help..other wise carb rebuild/cleaning
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
- jdvorchak
In the service manual , page 16-6, is the procedure. But it's not that complicated. Remove the point cover and grab the point cam and see if you can rotate it by hand. It will only go one direction and only move a few degrees but when you let go it should snap back. If it does you're good. Otherwise you have to pull the points plate and use some PB blaster on the moving parts to free them.Seb Astian wrote:Thanks, I'll check these things tomorrow. How do I know that the timing advance is working correctly, or what problems should I look out for?jdvorchak wrote:Hello and welcome to the forum. There is no shortcut to cleaning carbs. Running plenty of carb cleaner through them usually only results in clean float bowls but does little for the idle (pilot) jets and idle circuits.
2021 HD Triglide
John
2021 HD Triglide
John
- Tin Member
I cant agree more, a sign that these bikes are not perfectly tuned is they hang in idle. First reaction is there is a mechanical hangup, but it is a much more complex interaction between timing and carb. There is some good stuff on this site that explains what is happening.jdvorchak wrote:
One additional thought -- after you assure the timing is correct, synch the carbs. Then after you are sure that everything is perfectly tuned -- there is something else wrong. My bet is the bike will run much better after you tune it.
2004 GL1800 Goldwing
2004 Honda Shadow ACE
I was thinking exactly the same thing. Carbs that are out of synch will make the RPM drop slowly when you close the throttle.wajulia wrote:after you assure the timing is correct, synch the carbs.
A quick update on this and another question.
It turned out that my GL1000 was fitted with GL1100 carbs and that the crankcase breather wasn't connected.
Instead of trying to get the GL1100 carbs to run, I have bought and fitted a refurbished set of the correct carbs for the bike.
I am struggling to find a schematic or photos and guidance of how the crank case breather was connected. Does anyone have a photo of theirs?
- RB
tube goes from the engine up to the air box..
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
- RB
tube goes from the engine up to the air box..the pipes it connects to on both ends look the same. Two different things. there was a "puke" bucket on teh drain tube but yoiu don't have to keep it..open line to teh ground or put a small filter on/in the line if you want.
look here
http://shop.westernhonda.com/fiche_sect ... fveh=13029
look here
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
Sorry, I should have mentioned that this bike is a 1979. Was there not some sort of reservoir?
Can I run it without or will this effect the engine?
Some of them came with reservoirs of various designs but you have to empty them periodically. I find it easier to use a straight run of tubing and terminate it with a cheap fuel filter so that it self drains. I had that setup on my '79 engine for a long time and just set up the same thing for the '82 engine I just installed.
Those guys covered your question about the breather. But I'll say the slow return to idle had nothing to do with using the 1100 carbs. Guys have run 1100 carbs for years on 1000's. A "supposed" upgrade. The problem was probably the carbs themselves. But not just the fact of using those carbs.
- 22 Replies
- 1191 Views
Last post by olchris
- 12 Replies
- 243 Views
Last post by ericheath
- 420 Views
Last post by Hal
- 4 Replies
- 343 Views
Last post by Recycled Roadkill
