Charging system qustions
- childintime65
I just solved my overcharging problem by running the black regulator wire to the battery as suggested here on several posts. I presently do not have a relay wired in. Do I need this? If I do, what type of relay and how do I wire it in?
Thanks guys, this forum has been a big help to me keeping my 77 and 80 Goldwings on the road.
1976 GL1000
1977 GL1000
1977 GL1000
Re: Charging system qustions
I just did the same, you do need a relay. The Goldwings forum has specific info on this. I just followed along
There is nothing noble in being superior to your fellow human beings. Real nobility is in being superior to your former self.
~Hemingway
1978 GL1000
1987 Shadow VT700
~Hemingway
1978 GL1000
1987 Shadow VT700
From what I've read you do not need a relay because virtually no current flows in that wire.
If I was doing it I would want to make sure so I would connect an ammeter in place of the wire and confirm that for myself. If there is no current when the key is turned Off there is no need for a relay. If there is a measurable current you will need to figure out if it is enough to discharge the battery if the bike is parked for a couple of weeks.
- Rednaxs60
This is a good question, but for my dollar, the OEM has the sense wire to the regulator/rectifier switched through the ignition switch. The relay maintains the original design intent of having power through the sense wire when the ignition switch is turned on and non when the engine is turned off.Sidecar Bob wrote:From what I've read you do not need a relay because virtually no current flows in that wire.
There was a time when the sense wire was directly connected to the battery, but it was changed due to connection issues and changed so it was switched through the ignition switch. Here's a good article regarding this: http://www.electrosport.com/technical-r ... stem-works
Just my nickles worth, no more pennies in Canada.
Cheers
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2021 Royal Enfield Himalayan
2008 GL1800 (sold)
Ernest
2008 GL1800 (sold)
no pennies in Canada.... first it is the paper dollar.... now pennies... what is next? Oh the horror
Well, first there was the Canadian Pound but in 1858 they decided to follow the US and adopt metric currency......
Personally, I don't miss the 1¢ coin ( which was never officially called a penny in either the US or Canada). But $1 and $ 2 coins are a pain, especially when you start to walk funny because you have a bunch of them in your wallet.....
Maybe we should go back to 2 and 3 cent coins...<kidding>
I've got six pence
jolly, jolly six pence
I've got six pence
to last me all my life
I've got tuppence to spend
tuppence to lend and
tuppence to send home to my wife
I've got six pence
Discussing relays, I think we made a wrong turn somewhere!! (but I hate pennies myself).
- 10 Replies
- 875 Views
Last post by Toehead
- 21 Replies
- 951 Views
Last post by gdonlo04
- 3 Replies
- 458 Views
Last post by Track T 2411
- 4 Replies
- 293 Views
Last post by RB
- 14 Replies
- 946 Views
Last post by wolf_walker78
