I was wondering if there is a source for these seals. When I took my drive shaft to final drive off, the "grease" in the shaft section was like a thick syrup. Now what I would expect from something lubed by a Zerk fitting type of grease. I'm wondering if the seal to the final drive is leaking or the seal from the engine to propeller shaft is leaking. This is the seal I'm looking for. The small end on mine has the fiber cord showing so I know it's worn
Thanks for any info someone can provide.
'76 GL1000 drive shaft seal source
- 91267-371-003.jpg (27.64 KiB) Viewed 112 times
- calif wingnut
Re: '76 GL1000 drive shaft seal source
Thanks Calif Wingnut! Much appreciated!!!
-P.
-P.
