I got my Dyna ignition in today and installed it in the 79. It runs great but I had a real problem with the screws that hold the plate down. It seems the PO had put in some off the shelf slotted screws that were huge and it was keeping the plate from turning. I finally got it to work but I really need to find out where I can get some original screws?
I thought Randakk might sell them but I didn't see any there. I believe they are 6 x 12mm?
When I set the timing I couldn't get it dead on but it is very close.
Dave
Dyna ignition install
Re: Dyna ignition install
Others have shaved one edge of washers to pinch the plate using different screws. It’s a tight fit.
Why not check your local Ace or similar hardware store.leggman wrote:I got my Dyna ignition in today and installed it in the 79. It runs great but I had a real problem with the screws that hold the plate down. It seems the PO had put in some off the shelf slotted screws that were huge and it was keeping the plate from turning. I finally got it to work but I really need to find out where I can get some original screws?
Dave
Mine has every size you could think of both standard and metric.
78 GL1000 Original Owner 131k
Yep. Ace is the place. That's where I went. In fact, there are Ace hardware bits in each and every motorcycle I own. Metric is metric. Stainless and chrome are nice, too - and Ace has a nice selection of those, too. Of course, in your case, that won't be necessary!
- todd54219
I had to modify mine when I installed it several years ago. The two pickup bodies interfered with each other to get the timing set. Field modifications is the term that comes to mind. A little work with a file and no problems for about 6 years.
Todd
Todd
1976 Yellow GL1000
1976 Yellow GL1000
The newer ones have smaller pickups. I've never had that same issue with those. The old style yes.todd54219 wrote:I had to modify mine when I installed it several years ago. The two pickup bodies interfered with each other to get the timing set. Field modifications is the term that comes to mind. A little work with a file and no problems for about 6 years.
Todd
- 9 Replies
- 1116 Views
Last post by pidjones
- 0 Replies
- 417 Views
Last post by gltriker
- 6 Replies
- 876 Views
Last post by swampguide1
- 10 Replies
- 466 Views
Last post by bonestock3
- 21 Replies
- 1318 Views
Last post by Fred Camper
