Water pump leak. Again
Steevensi
Post by Steevensi »
Hi
Last fall I had coolant leaking out of the weep hole.
So I changed the water pump and all of the seals and gaskets that could be changed while doing that.
I did not rode the bike after that cause snow came in early.
This winter, oil started dripping from the weep hole....
And I know it’s my fault. I knew I torqued the water pump bolts too much and probably damaged the crush washers...
Anyway. If I have oil coming out the weep hole but no oil in the coolant, I should be able just to replace the crush washers and call it a day right?
I have removed the water pump last night and will be putting it back in tomorrow because I just got new oem crush washer.
Cheers
The Black Bike
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=59312
1982 GL 1100
1980 GL 1100 to be fix
1983 Honda Nighthawk 650 sold
1980 Suzuki A100
1974 Suzuki TS 250 sold
1992 Yamaha RT 180 sold
1976 Honda CB125 sold
2002 Suzuki Katana 750 sold
1982 Suzuki GS750 in boxes
RB
Re: Water pump leak. Again
Post by RB »
Double check the oil seal..I'd replace it..just be case it's such a PITA to get at it..
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her :(((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
5speed
Post by 5speed »
what rb said. if you didn't replace the oil seal and o ring that go between the water pump and oil pump..that may be the culprit.
77Gowing
Post by 77Gowing »
You ain't the only one around here that has had to redo a repair.
Good luck & best wishes to you.
"Less is More" Anonymous
77Gowing
2014 Yamaha 950 V Star (sold)
5speed
Post by 5speed »
77Gowing wrote:You ain't the only one around here that has had to redo a repair.
:oops:
I am glad I am not the only one who has to redo this. oil can be from..... seal in pump..... crush washers..... O-ring
I have found it was almost always the O-ring
Steevensi
Post by Steevensi »
I’ve changed all of the seals and the gaskets when I did this job. I think there was above 12 pieces in the kit I used.
I know for sure the 2 gaskets around the water pump has been changed.
My bet are the crush washers. They were really... crushed when I took them out. Easy to believe oil find a way around them.
The Black Bike
1982 GL 1100
1980 Suzuki A100
5speed
Post by 5speed »
did you change this seal and the o ring around it?
what I have found is that it is really... really.... really easy to pinch the O-ring when you put the pump into the housing
5speed
Post by 5speed »
rcmatt007 wrote:what I have found is that it is really... really.... really easy to pinch the O-ring when you put the pump into the housing
I slather Vaseline on the o-ring before I put the pump back in. It seems to work..
KY also helps sliding into tight places :twisted:
5speed
Post by 5speed »
rcmatt007 wrote:KY also helps sliding into tight places :twisted:
can I get an RX for that? :mrgreen:
Steevensi
Post by Steevensi »
5speed wrote:did you change this seal and the o ring around it?
is this picture from an 82? I,m pretty sure the pump doesn't look like that...
But anyway, I changed everything that could be changed when I reassembled the front end of the engine.
The Black Bike
1982 GL 1100
1980 Suzuki A100
Steevensi
Post by Steevensi »
I don't see how I could pinch the small seal (on the oil side). You push on the water pump to install it so the seal is squezed in there.
The one that could cause trouble is the big one on the coolant side. This one is easy to roll out of it's groove.
Or maybe I did not understand what you meant??
The Black Bike
1982 GL 1100
1980 Suzuki A100
the one easiest to pinch is the one in the groove, and yes, it would be coolant leaking there. Still goes back to seal on water pump-oil side.... crush washers.... or O-ring for an oil leak
