Loose stator
- Dirty Dave
Loose stator
My diagnosis of the loud rattle in my engine was correct. My trusty stethoscope located the noise from the rotor/stator area of my 79 Wing. My apologies to Electrosport as I had thought the stator coil had come loose but it was user error on my part. All 3 stator bolts were loose enough to make rotor magnet contact with the stator.
Here is my question. I can't find torque specs or an mention of Loctite used for the 3 bolts. How do y'all mount the stator?
It had lasted two years before failing.
1978/9 GL1000
1997 Honda Valkyrie
2018 Kawasaki Z900 RS
1997 Honda Valkyrie
Re: Loose stator
Check here: https://www.ngwclub.com/forum/viewtopic ... 90#p424090
If that does not cover it then use a standard torque from here: https://www.ngwclub.com/forum/viewtopic ... 96#p453196
And yes i would definitely use some thread locker
- Dirty Dave
Re: Loose stator
Turns out the screws are stock and Loctite will start to degrade after 350 degrees F.
How hot does our engine oil get?
1978/9 GL1000
1997 Honda Valkyrie
1997 Honda Valkyrie
Re: Loose stator
Waaayyy less than 350. I'd say 250-275 max. And that's on a hot day. Usually less than 230.
- Dirty Dave
Re: Loose stator
Thanks desert refugee. I'm not fooling around this time and will Loctite the 3 screws holding the stator just in case.
Next time I have to pull the engine again I'm putting pedals on the Wing.
BTW We were tied for motorcycle ownership but you one upped me with the CBX-Z...........
1978/9 GL1000
1997 Honda Valkyrie
1997 Honda Valkyrie
- Dirty Dave
Re: Loose stator
Looking at stator replacement videos online nobody is using Loctite or torquing the screws or bolts more than hand tight.
Guess I just got lucky.
1978/9 GL1000
1997 Honda Valkyrie
1997 Honda Valkyrie
Re: Loose stator
Well DD, I wasn't really looking. It sort of found me. Not a contest. Just life.Dirty Dave wrote:BTW We were tied for motorcycle ownership but you one upped me with the CBX-Z...........
- Dirty Dave
Re: Loose stator
The stator I bought through Randakk's website goes in so tight I had to worry it in place using the 3 screws. It's going nowhere, impossible to get loose. I also used Loctite on the screws just in case they decided to go for a walk.
Down side is if I ever have to do this again, I'll hafta use explosives to remove the stator.
I hope this seemingly unique problem helps someone else out there. I haven't read of anyone else having a stator come loose. Maybe I should keep my RPMs under 13K..........
1978/9 GL1000
1997 Honda Valkyrie
1997 Honda Valkyrie
Re: Loose stator
I figure since I have to use the impact screwdriver to get those screws loose, a couple of good taps on it to tighten them should be about right...
- Dirty Dave
Re: Loose stator
Thought of that Bob.
I get nervous with steel screws into aluminium though. I have enough Heli coils in the Wing. I'm sure it would work but with my luck with wrenching...................
1978/9 GL1000
1997 Honda Valkyrie
1997 Honda Valkyrie
- RIP: cookie
Re: Loose stator
13K is the limit ....
Re: Loose stator
I wonder if there's room to use regular M6 flange head screws? Then you could just torque them normally.
- Dirty Dave
Re: Loose stator
Thought of that as well and yes, there is room. The stator went on so tight that I decided to stick with stock screws.
They seem to hold for everyone else. I was also too lazy to go to the store.
Thanks for the tip regardless from a fellow Canadian. I have until next Spring to put the engine back in.
I decided to save $586 CDN for the plate and just ride the Valkyrie this season. If I fix the Wing too soon I will want to ride it.
1978/9 GL1000
1997 Honda Valkyrie
1997 Honda Valkyrie
- 4 Replies
- 178 Views
Last post by BlueThunder
- 13 Replies
- 323 Views
Last post by salukispeed
- 3 Replies
- 416 Views
Last post by Sidecar Bob
- 11 Replies
- 330 Views
Last post by NCScooter
- 8 Replies
- 414 Views
Last post by Pony Ruiz
