loud clunk when I engaged starter this morning
- Zinc Member
1982 GL1100
Went to start bike this am and hit starter button , all I got was a little rotation and a loud clunk after the starter engaged. Tried several more times and lights and dash indicators came on with key and lights dimmed with push of starter button , no change . Charged battery to full and no change. Have not had a chance to fully check out solenoid but primary resistance shows 3ohms and it clicks when 12 volts is applied to rear 2 spade terminals in connector block closest to threaded studs marked motor and battery . Have not checked for continuity across the 2 studs yet with the 12 volts activating the solenoid switch.. All comments and collective wisdom appreciated .
1982 gl 1100
- Earl43P
Re: loud clunk when I engaged starter this morning
Pull your spark plugs out and try it again.
Might be that fuel filled a cylinder (hydrolock) and you should rule that out.
Expect a good spray of fuel to spew out and plan accordingly.
2008 GL1800 "yawn"
KTM390A “Hootinanny”
04 ST1300 DDDD (Double darksided daily driver) Sold 4/2022
93 GL1500I Double darksided and SOLD 3/29/20.
99 Valkyrie IS, Fast Black Double Darksided
"Fishtailed, flipped and flung me, but wearing it well". Sold!
82 GL1100 retired DD, needs work.... Sold 3/3/17
Ugh. Hope it's not hydrolocked. I thought at first you might have starter clutch issues, but sounds like Earl may have the next step outlined...
Yep for sure check for hydro lock then check the batt ground to the frame. Have seen corrosion there cause the exact same issue.
Kill switch in STOP position!!! You could have a giant fireball if not. Hope it wasn’t a loud kind of a crack sound.
ericheath wrote:Kill switch in STOP position!!! You could have a giant fireball if not. Hope it wasn’t a loud kind of a crack sound.
Do it outside. Not near anything the gas can hurt. If there is fuel in a cylinder it can shoot out quite some distance.
- Zinc Member
clunk not crack ,will pull plugs tomorrow and check for hydrolock although I suspect starter or solenoid issues. also will verify grounds . Bike sat outside last night in the rain .
1982 gl 1100
- Zinc Member
I pulled the starter this afternoon , several sheared teeth on 1 of the planetary gears . Starter was not oem , was WPS 18600N made in Taiwan.
hope to get replacement tomorrow
1982 gl 1100
- chewy999
I would be worried why the teeth had sheared, and where the bits of metal went!
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
Still might be looking at a hydrolocked root cause. If so, you might have gotten lucky the starter bore the brunt - if that's what it was.
- Zinc Member
The sheared teeth are in the planetary gear box of the starter which is isolated from the engine no worries there. I will check out the hyrolock possibility once the new starter is in place plugs are already out and sprag clutch is definitely not engaged . Will keep you posted.
1982 gl 1100
- salukispeed
Any pieces of teeth will be contained in the starter nose and can not travel into the engine. This is a common failure when the Compressed steel (sintered) gears are not properly processed and heat treated and even normal use can result in this failure. For sure a locked engine would be over load on the gear set and worth investigating.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
- Zinc Member
I have been reviewing my last ride before the starter locked up and I recall when I started the bike I thought I heard an odd metallic noise briefly but the bike was running and there was no more odd noise , I suspect that was the planetary gear teeth shearing as the bike started . The sheared metal teeth then settled to the bottom of the gear case waiting to jam the starter when I touched the starter button the following morning . I do not think Hydrolock was the cause of the broken teeth but I will still investigate that option . the small bits of hardened steel would have been sitting in teeth of the ring gear waiting to jam the planetary gear when I touched the starter button.
1982 gl 1100
You can just see if it turns over with the rotor.
- salukispeed
Remember to only turn it clockwise/tighten the 17mm bolt.
Honda 72 CL100 sold
1970 CT 70
1970 CT 70
- 12 Replies
- 262 Views
Last post by rod willis
- 24 Replies
- 1238 Views
Last post by stephen.mangnall
- 18 Replies
- 317 Views
Last post by CYBORG
- 7 Replies
- 265 Views
Last post by Red2trike
- 208 Views
Last post by Mrirbic71
