In restoring my '75 and '76 I'm trying to stay as close to original as possible. In trying to reuse these factory clamps - they are TOUGH to get on correctly and I'm struggling mightily. If the small extension piece does not slide under correctly, they bend.
Is there a trick I'm missing?
Coolant hose clamps
Coolant hose clamps
76 GL1000 LTD
2019 DCT Airbag Tour
Austin, Texas
76 GL1000 LTD
Austin, Texas
- tlbranth
Re: Coolant hose clamps
I think the clamps themselves are pretty good. The positions they have to be in, however, indicates that Satan was in on the design. I found that renovating the clamps before using them helps a lot. I wrote something about this a few years back but haven't been able to find it. The jist is: assemble the clamp loosely over a comparably sized piece of steel pipe mounted in a vise. Then turn and hammer the clamp to get the wrinkles out.
When assembling, put the clamp on the hose first and then pull a muscle trying to get the hose on the pipe. If you put the hose on first and try to stretch the clamp around, you'll bugger up the clamp. Good luck. Let's know how you do.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1975 GL1000
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1975 GL1000
1970 CB750
As usual, I used your written tutorial to accomplish the goal. Wasn't easy but I began to feel when the clamp was getting into a bind and then backed off and tried again until the extension slipped under and tightened down correctly.
Many many thanks........
76 GL1000 LTD
Austin, Texas
76 GL1000 LTD
Austin, Texas
- tlbranth
Glad you got it
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1975 GL1000
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1975 GL1000
1970 CB750
- 2 Replies
- 282 Views
Last post by sgwilly
