Brake pads
tlbranth
Brake pads
Post by tlbranth »
Hydraulics work great but I can dang near stop the thing better with me feet. Pads are plenty thick and I've cleaned them a time or two with BrakeClean. My CB750 brakes beat the '75GL hollow on braking with a drum rear and single disc front. So any recommendations for good pads? Not 'designer' pads though.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
BlueThunder
Re: Brake pads
Post by BlueThunder »
Use EBC semi-sintered (aka semi-metallic) V series pads. They stop quite a bit better than organic or ceramic pads. These pads are safe to use on stock discs and won't gall them.
You can improve the brakes further by using stainless steel braided brake lines and going to a 5/8" master cylinder. Bike will stop on a dime! Do the back this way as well and you won't be disappointed.
...Brian
1977 GL1000 - Ox
tlbranth
Re: Brake pads
Post by tlbranth »
Front has new stainless lines and a new 5/8" master. Feel improved but braking didn't. Lines on back are new OEM
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
BlueThunder
Re: Brake pads
tlbranth wrote:Front has new stainless lines and a new 5/8" master. Feel improved but braking didn't. Lines on back are new OEM
Terry, are the pads new? Are you using the stock T-joint? I ran brake lines from caliper directly to the master cylinder using a double banjo. I'm assuming that you have fresh DOT3/4 brake fluid and properly bleed?
...Brian
1977 GL1000 - Ox
tlbranth
Re: Brake pads
Post by tlbranth »
Stock t-joint. New ss pistons, seals. New dot4 fluid. Pads are what was on the bike when purchased a few years ago. The pads seem to be the weak link here.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Oldewing
Secretary
Secretary
Re: Brake pads
Post by Oldewing »
With everything that you have listed about your system, yep, new pads are in order me thinks.
With a new master and SS lines, mine stop in a "useful" distance now, not up to newer bikes, but way better than when it was new.
Steve81GL1100
Re: Brake pads
Post by Steve81GL1100 »
+1 on the EBC pads. Replaced my old (3 seasons, 10k miles plenty of meat left) kevlar-organic pads over winter with the EBCs and it made a significant difference. Running new OEM lines, btw. Upgrade to ss is a future project
Steve
Steve
1996 BMW R1100R
tlbranth
Re: Brake pads
Post by tlbranth »
OK I ordered some semi-sintered EBC pads for the rear to see how they do. I've had good luck with EBC stuff (mostly rotors) so I'm sure this'll do the job. Thanks ev. for your help.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
jdvorchak
Re: Brake pads
Post by jdvorchak »
Personally I stay away from the new designer pads. Kevlar, ceramic etc I leave that to to the race bikes. I find that HH sintered or semi sintered seem to work the best on all of the old bikes and my newer Harley's. Yes they dust but they don't tear up the rotors and they have great initial grab and hold.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
Sidecar Bob
Re: Brake pads
Post by Sidecar Bob »
FWIW, I've been using KMG carbon kevlar pads on both of my bikes for a few years and I like them. They don't seem to have worn the discs noticeably. The same ones fit all calipers on my 'Wing and my 650's front and at $23CAD/18US for 2 pairs they are cheap enough that I keep a few on hand.
chewy999
Re: Brake pads
Post by chewy999 »
+1 on using EBC pads, use them on my CB1300 as well. I think as as long as you buy a reputable brand things will be ok, but with brakes (and tyres (tires)), I always try to buy the best I can afford.
anim-cheers1 anim-cheers1 anim-cheers1
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
gdonlo04
Re: Brake pads
Post by gdonlo04 »
Q. In the Clymer's book, it reads to notch the pad if your rotor is solid and does not have holes. This recommendation is for wet stopping and water transfer. What are your thoughts/ experience with notching pads?
chewy999
Re: Brake pads
Post by chewy999 »
Wouldn't do it. Just accept that braking takes longer in the wet and rode accordingly. If you start messing around with them, daresay you compromise any warranty you may have. Just my humble opinion.
Previous Rides,
Current bikes
Re: Brake pads
An older Wingrider told me very early, that to stop these bikes quickly, you had to pull the clutch in. I was complaining that I just didn’t think it would stop fast enough for an emergency stop. I tried it. It makes a huge difference in the stock setup. Huge. I was new to riding at the time and was about to give up on it.
Sintered brakes chew mine to pieces fast.
Sidecar Bob
Re: Brake pads
That should be the case for anything with a manual transmission. People that have only ever driven cars and only ones with automatic transmissions get used to the automatic transmission shifting into neutral automatically so they don't think about having to disengage the drive themselves.
When I took the bike license course in '85 we were taught the "push-pull" method: Push down with both feet while pulling in with both hands. For a beginner it removes having to remember which control does what from the equation.
