Valve cover oil leak
I have completely restored both a '75 and '76. Everything is dialed in and running great. One annoying thing is that even with OEM rubber gaskets installed, BOTH sides of BOTH bikes leak oil along the bottom. Is this just something ya have to live with? Or, apply sealer (type?). The oil collects directly along the base area and not from around the bolts (new grommets on them as well).
As always,
Thanks for any help.
As always,
76 GL1000 LTD
2019 DCT Airbag Tour
Austin, Texas
76 GL1000 LTD
Austin, Texas
Re: Valve cover oil leak
New rubber grommets under the bolts? Makes a big difference.
- BlueThunder
I have found that some valve covers are not "flat" (most likely warped by heat or improper tightening), thus allowing oil to weep or leak. I have used HondaBond (or ThreeBond) gasket sealer (the one that doesn't harden and remains semi-plyable) does an excellent job in stopping the leaks. Easy to remove with a rag dabbed in gasoline for the next time after checking valve clearances.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- RIP: cookie
Some (not all) aftermarket rubber grommets/washer thingies are too skinny to apply enough pressure ....
- Steve81GL1100
Do some checking to make sure it's actually the valve covers leaking. I have a leak on the left side of my 1100 that I first thought was the bottom of the valve cover gasket leaking. Replacing the gasket and bolt grommets had no affect. Further investigation showed it to be the front cam seal weeping, and the oil naturally follows the vc gasket down to the bottom, off an exhaust stud, and onto my boot...
Steve
Steve
Steve
1996 BMW R1100R
1996 BMW R1100R
- hatchward
My 82 drips on my left boot even after replacing all grommets ,gaskets,shifter shaft seal and swapping valve covers left to right.I gave up.Its a vintage motorcycle.It's supposed to leak
1982 GL1100 Std - Daily Driver
1982 GS750SZ Katana - Mostly Unmolested
1998 Valkyrie - Latest Aquisition
1984 GL1200 Aspencade - Undecided Project
As always..........
I am very appreciative of the responses and the knowledge held within them.
76 GL1000 LTD
Austin, Texas
76 GL1000 LTD
Austin, Texas
- Steve81GL1100
I keep trying to convince myself that. If it was any other make of bike, I'd be fine with a small drip. Hondas are not supposed to leak, though....hatchward wrote:I gave up.Its a vintage motorcycle.It's supposed to leak
In my case, I think I must've nicked the new cam seal during installation. I will replace it, but I'm not that motivated right now so I put up with it. I'll take care of it next winter when I do cam belts again and already have it apart.
Steve
Steve
1996 BMW R1100R
1996 BMW R1100R
- 77Gowing
I too have a mystery drip. It is intermittent and only shows up after a few days layup. I just keep an eye on my oil and live with it. I too will wait until it's belt changing time to replace the cam seals, where I think this is pobably coming from.
I used OEM VC seals & Randaak VC grommits.
"Less is More" Anonymous
77Gowing
2014 Yamaha 950 V Star (sold)
77Gowing
Mine does the same thing and mostly on the left side, too. I've tried lots of things over the years like laying a bead of silicone in the grooves in the covers and letting it cure before assembly and adding rubber washers between the bolt seals and their chromed caps and a few years ago I even splurged on a set of bolt seals and cover gaskets from Georgefix. When that stopped the covers from leaking (I think) I noticed that the oil is coming from the timing belt housing so it looks like the camshaft oil seal is the culprit. I have been wondering if the oil is getting on the timing belts and whether that is a bad thing but hopefully they will hold up until I install the new engine, which will have brand new oil seals and timing belts.
- hatchward
I rebuilt the left head a couple of years ago after a belt snapped so everything is new.I just live with it.
Old school to fix this problem is a product by 3M called "Emblem adhesive". Most call it elephant snote, cause it,...well has the consistence of snote. A layer between the gasket and the head does the trick
- hatchward
Thanks Cyborg,I'll give it a try next time I adjust the valve clearance.
- jdvorchak
+1 on the Honda bond grey. It never really dries and is easy to remove if needed. A little goes a loooonnnggg way.
I use an acid brush to paint both surfaces with a very thin coat, let it sit for 5 min then put the parts together.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
With new Honda gaskets and bolt rubbers I still get some light seeping on both sides after every ride. Brake side is the worst. But very little and easy for me to live with. Just wipe er down a bit.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
- 8 Replies
- 461 Views
Last post by Oldewing
- 7 Replies
- 313 Views
Last post by ritalz
- 259 Views
Last post by txtriathlete
- 4 Replies
- 247 Views
Last post by gltriker
- 11 Replies
- 1079 Views
Last post by robin1731
