Carburetors question
- andorragl
Hello,
I am rebuilding my carburetors and I have some doubts. The # 4 carburetor hole is plugged, the other three are open. It is normal?
Looking from the other side it seems that it has always been like this, but it seems strange to me that it is blocked. I have seen many posts and many manuals on carburetors and it is something that nobody had mentioned.
- Carburetors.jpg (93.32 KiB) Viewed 464 times
1976 GL1000 LTD
1995 VT1100C2 ACE
2003 CB1300F1 SUPER FOUR
1995 VT1100C2 ACE
- andorragl
Re: Carburetors question
I carefully put a toothpick through the hole and almost loosely opened it. I would say this has always been blocked. Lighting from the other side is seen as if it was badly stamped. Is it possible this has been like this for 42 years? Will this motorcycle have ever worked 100% fine?
It's incredible!!!
I would appreciate any comment.
Here you are some pics.
It's incredible!!!
- Carburetor #2 with normal full open hole
- DSC06521.JPG (97.12 KiB) Viewed 426 times
- Carburetor #4 with plugged hole and iluminated from oter side (bowl side)
- DSC06525.JPG (70.42 KiB) Viewed 426 times
- Closely
- DSC06524.JPG (67.23 KiB) Viewed 426 times
- Carburetor #4 hole opened, plug only held by a point. Then I have completely removed it.
- DSC06526.JPG (80.6 KiB) Viewed 426 times
- The small plug
- 20180403_225830.jpg (56 KiB) Viewed 426 times
1976 GL1000 LTD
1995 VT1100C2 ACE
1995 VT1100C2 ACE
- scootsx2
Hmmm. Interesting. I suppose the hole may have become plugged over the course of time. I'm surprised one of the carburetor gurus on the board hasn't responded.
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
There should be no through holes there. The only one that was correct is now bad too. If you look at the piece you knocked out it made of the same material as the carb bodies. If you look in the carb throat you can see the casting going to that spot.
Why is it there? Maybe a hole used for indexing when machining the carbs. But it was plugged when it was cast. Should be now.
- salukispeed
I believe That hole is not tied to any fuel or air passages except the aircleaner side of the carb throat and is sealed off by the bowl gasket so would have no effect open or closed. Any vacuum would be only air filter restriction and not important. It is not uncommon to see such things in Zinc Castings like these. .
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
That is a big hole. If it didn't matter I doubt Honda would have gone to the trouble to cast it with the plug in it. I wouldn't trust the gasket to seal that big of a hole. Your bike, do as you see fit.
- delling3
I would expect that judicious use of some JB Weld or PC-7 epoxy could fill those holes. That way there wouldn't be any question about the gasket sealing it or not?
delling3
1979 Yamaha XS750SF
Previous:
2006 Kawasaki Concours: Sold
1979 Yamaha XS750SF
Previous:
- andorragl
I had certainly thought about itrobin1731 wrote:There should be no through holes there. The only one that was correct is now bad too.
Yes, is the samerobin1731 wrote: If you look at the piece you knocked out it made of the same material as the carb bodies.
But, in fact, the carburetor 4 was the one that worked worse, in the cold start without choke the cylinder 4 did not burn, instead with the choke or with engine hot, yes. The other three burned good in all conditions.
Other thing, The gasket have a hole there, the bowl is marked but closed.
I'm still un doubt. It would be nice to see a picture of a carburetor in good condition.
Thank you very much for your comments.
- 100-1505_gl1000_float_bowl_gasket.jpg (19.19 KiB) Viewed 357 times
1976 GL1000 LTD
1995 VT1100C2 ACE
1995 VT1100C2 ACE
I don't have any pics but I've seen a few GL1000 carbs.
- AussieGold
here is the best pic i could find of a dismantled carb. unfortunately does not show the bottom of that hole.
a previous owner may have cleared them, perhaps,
as has been suggested , i would use some JB weld or similar to fill all four holes. a previous owner may have cleared them, perhaps,
Mentor to all self appointed (and genuine) GURUS.
An LTD is........it just is.
- mcgovern61
I am not sure if this would be an equivalent in the 1100 carbs, but in the same area on the 1100 carb, it appears the hole is filled and sealed with a brass ball?
Gerry
Current ride: 82' GL1100
1st ride: 81' Suzuki GN400
Went through all my 1000 parts carbs. 4 boxes worth. 20% had the hole through. But you could see that when Keihin cast the carbs it was plugged. Barely but plugged. That means the piece that was there fell out and went through the engine. (small and soft enough to not do any damage) Or at some point someone knocked it out while cleaning. At any point it was plugged when new. And when it falls out it changes nothing.
Saying that, the fact that the OP had troubles with the number four carb had nothing to do with that plug.
- andorragl
I'm sorry. I didn't mean to offend or doubt you. Of course I trust what you say.robin1731 wrote:I don't have any pics but I've seen a few GL1000 carbs.
I'm relieved to know this, it's the really important thing.robin1731 wrote:At any point it was plugged when new. And when it falls out it changes nothing.
In that case I'm sure when the rebuilding is finished it will work perfectly again. I will keep you informed.robin1731 wrote: Saying that, the fact that the OP had troubles with the number four carb had nothing to do with that plug
Thanh's again.
1976 GL1000 LTD
1995 VT1100C2 ACE
1995 VT1100C2 ACE
- andorragl
I'm sorry I completely forgot to report and close this thread.
I finally mounted the carburetors and to this day they are working perfectly.
I've no idea how can I close it.
1976 GL1000 LTD
1995 VT1100C2 ACE
1995 VT1100C2 ACE
Your comment closes it for me. Glad to hear the problem is resolved.
- 22 Replies
- 1670 Views
Last post by Dr. Frankenstein
- 57 Replies
- 3194 Views
Last post by gltriker
- 0 Replies
- 295 Views
Last post by ericheath
- 13 Replies
- 3635 Views
Last post by AL Smith
