Sure did. I try not to miss Mike's installments. Forgot about that! Thanks Robin.
I wonder if just running any old 87 octane blend would serve the same function as "Techron"?
GL1000 - intake valves w/ carbon build on stems
Re: GL1000 - intake valves w/ carbon build on stems
- jdvorchak
I doubt that running 87 would clean anything. It might keep the buildup from getting worse. You have to clean it first.
The problem with carbon build up is that it has a rough surface that attracts more carbon build up. So it will only get better with cleaning it first then do what's necessary to keep it clean.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- tlbranth
I've seen a few bad words said here about using water to decarbonize an engine. I've done it in the past by setting the engine speed up a bit - maybe 2-3k rpm and using a squirt bottle to shoot water into the intake manifold. I've never had the satisfaction of seeing what the actual results were but I can tell you that a LOT of black stuff came out the tailpipe. My dad used to do this on his car, Click and Clack have recommended it and by golly I'll recommend it too.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- BikeMaine
- 10 Replies
- 765 Views
Last post by Lucien Harpress
- 13 Replies
- 473 Views
Last post by katmol
- 103 Replies
- 14687 Views
Last post by Hoops
